Someone recommend an A4 cam.
Old Dec 29, 2002 | 08:07 AM
boomcase's Avatar
Default Someone recommend an A4 cam.
Looking for A4 cam that will idle good and run good without any tuning. Mods are in sig. Thanks
Looking for 15 to 20 more hp.
Old Dec 29, 2002 | 08:25 AM
2001 Pewter WS6's Avatar
Restricted User
Default Re: Someone recommend an A4 cam.
I have a good cam that would work well with your NOS setup. Comp Cams 220/226 .563/.570 114LSA. I ran an 11.70 with full interior with it and stock heads... You will need to bump up your idle a little. I will be pulling it out soon as my hew heads and cam gets here which should be in a week or two. It only has about 500 miles on it. $250.00
Old Dec 29, 2002 | 09:38 AM
LS1Bird00's Avatar
Should be ok as long as 114Lsa. Just a question off the subject, I noticed you have a vortex muffler in your sig. I have the same and was wondering how your's sounds with headers. I still have the stock manifolds, but I'm very happy with the $80 muffler.
Anyway's sorry about changing the subject. Are you planning on keeping the bottle with your new cam?
2000 Formula M6
Lid,!FRA,vortex, 160ts
Old Dec 29, 2002 | 09:41 AM
Ragtop 99's Avatar
No tuning and your mods leads me to suggest that a 220/220 115 +4 is the largest I would go. This size is still hit or miss in an A4 as to tuning, especially idle speed and not having an SES for random misfires.
If you want a very high probability of not needing any tuning or having codes, I would look smaller, consider a 214/216 115 +2 or 216/216 115 +3.
Old Dec 29, 2002 | 10:14 AM
Crazyquik's Avatar
Thunder Racing 224/224 on a 114 is the biggest I would go. I'd probably look for something with the same ramp rates but around 220-222 duration on a 114 LSA.
Maybe even a 220-222/216-218? Something like the specs Patrick G used on his last cam. I think his was a 220/216?
J.
Old Dec 29, 2002 | 01:23 PM
boomcase's Avatar
Thanks for the info guys.Ragtop u mean advanced right +2,3,4.i think. Ls1 bird with the headers and offroad pipe it was really raspy and friggin annoying. I just changed to a magnaflow muffler and it is much better now.Love the deep sound.Drivability is key here for me with the cam not quitesure on if to change gears to 342s.this is my only car.
Old Dec 29, 2002 | 01:45 PM
Restricted User
I have run the cam with no tuning when it was first installed. I just raised the idle. Never set any codes.
Old Dec 29, 2002 | 02:24 PM
Ragtop 99's Avatar
Yup +2,3,4 is advance.
2001 Pewter: I know it was plug and play for you, but when you get to 220 duration the odds of an A4 acheiving an acceptable idle and not having any codes starts to drop.
FWIW, m6 cars are luckier, their higher factory idle speed allows for a better shot at no problems.
Old Dec 29, 2002 | 02:33 PM
boomcase's Avatar
Ok guys thanks again but what cam would u use if u were me for the money and power and the no tune please be specific.remember this is my only car.
Old Dec 29, 2002 | 02:54 PM
99Z284MAC's Avatar
talk to Trevor at Texas speed and performance in the sponsors list------->>>> he told me I could go with a 228/228-588/588 111 lsa with converter headers 3.73 gear and tuning with stock heads
Mark Culbertson
Giftfromdc@aol.com
Pewter 99 Z28 with flow master exaust K&N cold air computer soon to have cam headers heads converter and gear. I'm also spraying a 150 shot.
Old Dec 30, 2002 | 07:24 AM
Larry's Avatar
If you are looking for only a 15-20 hp improvement then an 01 or 02 Z06(LS6) cam would do the job, pass emissions and not require re-programming.
Old Dec 30, 2002 | 03:28 PM
Crazyquik's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 99Z284MAC:
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">He wants a cam for stock tuning.
J.
Old Dec 30, 2002 | 08:43 PM
Constrictor 98TA's Avatar
From what I've been reading, you probably wont want to go with anything larger than a TR220 or the MTI B1 cam with stock programming. Anything more than that, and you're just wasting your time, cause the cam wont be able to work to its fullest potential, and you'll have a lot of idling problems with your A4.
Old Dec 31, 2002 | 12:12 AM
Jay Johnson's Avatar
218/218/.560/.560 114 ls
$250 gets it.
Jay Johnson
jayjohnson@rocketmail.com
Old Dec 31, 2002 | 12:32 AM
rich's Avatar
speed inc. has a custon grind comp. cam i think it is cc custom 1 .563/.563 220/220 114 (a4) or 112 (m6) ls. They claim no tuming and emissions frendly.
