SCE Titan
This is just a warning.
I am using Cometic....I have had zero problem with them...even up to 18#s boost.
were timed. I noticed the with each re-torqueing, I gained about 1/8 of a turn on ALL fasteners. The only leak I've had since I put these on was a pump to block gasket. The felpro 1041's I used the first time seeped and the heads warped but I didnt re-torque them at all. Felpro recomends two re-torques with those. As paranoid as I am now about re-torqueing, I'd retorque anything I used twice even though its definatly overkill.
Are you referring to the ICS with the Combustion seal wire?
Copper gaskets will almost always weep water, it's the price you have to pay to run the low numbers at the track and the big numbers on the dyno.
Only reason to run a copper gasket is if you are o-ringed then it doesn't matter much since the water will not make it in to the combustion chamber.
