(cam only) Texas Speed Torquer v.2 come in
#61
Originally Posted by LS1TORQ
im starting to really consider this cam, it will be going into my DD. Im just worried that it is too big for a DD. Can some one chime in on its idle and drivability, I know TSP claims a like stock idle quality. Also what rpm are you guys shifting at?
It wouldn't bother me to use this cam in a DD, but we all have our own opinions on what is driveable and what is not.
#62
Originally Posted by oneBADDz
If you're cammed you need a lid even mroe than a stock car. If it = 10-15hp on a stock car, you REALLY need one being cammed. you're demand for air is much greater than stock
Back to the original topic, I think some of you are being a little less than honest if you say "it drives like stock till 4K rpm...." No way does a cam with a 230 duration drive like stock at low rpms, regardless of how great of a tune, you're going to lose low end power with higher durations.
#63
ive had good luck with my t2. i wouldnt put it in again but i dont totally regret it. i made decent power and driveability is great imo once u mess with the lidle a bit. i just wish it made more power below 3k. my g/f's stock c6 will pull away from my car like a frieght train in a top gear roll on. (from cruising rpms) but get it up in the rev's and it will pull all the way to 6800 no problem
#64
why would you do a high gear roll on though. if you put it in the right gear woudnt you leave her in the dust?
#65
If I drive an auto on the street with the T2, there is no way it would be undesirable in an M6 car on the street.
#66
