PTV clerance - quick question
Old May 10, 2007 | 03:05 PM
Red 01SS's Avatar
Default PTV clearance - quick question
This should be ok BUT...
243's milled to 60cc with 2.02 and 1.57
Cam is a Comp grind 228/228 588/588 114+2, I will be using stock gaskets.
I would like to make sure it will go together before they get shaved.
Thanks guys,
Chris
Old May 11, 2007 | 02:28 AM
Red 01SS's Avatar
All night and nobody?
These heads are getting milled tomorrow
Old May 11, 2007 | 02:58 AM
Xtnct00WS6's Avatar
60 cc's is might be too much with aftermarket valves (unless your willing to flycut). I have 243's milled to 63cc's with the same sized valves and a TR224 on 114. It's right within tolerance. I also have .045 gaskets too. Just make sure to measure!! And be willing to flycut cause I think your right within tolerance.
Old May 11, 2007 | 03:15 AM
Red 01SS's Avatar
Thank you. Its not exactly what I wanted to hear but...much appreciated
Old May 11, 2007 | 03:49 AM
PREDATOR-Z's Avatar
.020 mill on that cam with stock gasket should be fine, but always better measure.
Old May 11, 2007 | 12:25 PM
Red 01SS's Avatar
Thanks Predator.
Old May 11, 2007 | 02:34 PM
Xtnct00WS6's Avatar
Let us know how it comes out! .020 like Predator said should be a good bet. Good luck.
Old May 11, 2007 | 06:38 PM
Red 01SS's Avatar
Should be a week or 2 before everything is back together but I'll let you guys know how it turns out.
