Cam suggestions?
Old May 11, 2007 | 10:55 PM
k-mart's Avatar
Default Cam suggestions?
I've been trying to read up as much as possible on cam selection but I haven't really found what I'm looking for. Mods will be a set of 241's with dual springs, LS6 intake, TSP long tubes, no cats, ported/polished TB.
I'm not looking for a screamer at the track but its not a DD so driveability isn't too critical. I want a broad power band with good torque and a mean sounding idle. I'm thinking about something along the lines of a low 230's duration with lift a bit over .600 lift and 110-112 LSA. Any ideas?
I was also thinking about milling the heads down a bit to raise compression. If I do, how much and what length pushrods would work well?
Thanks in advance.
Kevin
Old May 12, 2007 | 07:51 AM
Patrick G's Avatar
LS1 Tech Administrator
Bingo, you've answered your own question. Find a cam in the low 230s (preferable a single pattern), around .600" lift and keep the LSA between 110-112 (don't forget +4 advance with stock heads). There are some nice customs that fit this bill and certainly a few shelf cams that fall into this range as well.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 12, 2007 | 09:16 AM
JPH's Avatar
JPH
224/228 .585/.585 112+4 will surfice very well for your application. i would advise more engine work, heads, compression, etc... for 230+ duration camshafts.
Old May 12, 2007 | 12:47 PM
k-mart's Avatar
Thanks, Patrick. Something along the lines of the F12 should work well, then? I'm thinking about a custom grind like so, 230/230" .60X" or .61X" 110+4 LSA.
Would you advise milling the heads down a little? Maybe .030"? If I do, will I need slightly shorter pushrods too?
Old May 12, 2007 | 02:22 PM
Patrick G's Avatar
You will need longer pushrods than stock if you run stock chamber size and gasket thickness. If you mill and run a .040" gasket, you may get by with 7.400" pushrods.
If you go over 11.0:1, you won't need to advance the cam +4. Maybe +2.
__________________
Old May 13, 2007 | 11:49 PM
k-mart's Avatar
I found a 230/234 .595/.585" 112LSA (I think its +4.) for a good price. I'm thinking that the money saved by going with it will free up cash for a .040" gasket. How's that sound?
Old May 14, 2007 | 06:45 PM
k-mart's Avatar
Anybody?
Old May 14, 2007 | 07:51 PM
LS1rulz's Avatar
G5X2 would be perfect.
Old May 14, 2007 | 08:36 PM
Patrick G's Avatar
As long as the lobes look smooth and pretty, I'd say you've found your cam. The thinner gasket is a smart move for torque too.
__________________
Old May 14, 2007 | 08:41 PM
k-mart's Avatar
After some research I found that stock head gaskets compress down to the .050-.052" range. Would it be possible to mill the heads an extra .010" down to .040" and achieve similar results to the thinner gasket? I realize that the quench won't be improved, but chamber size should be close. Or would this cause me to need to flycut negating any $ savings by going with stock gaskets?
