106 lsa
Old May 12, 2007 | 10:03 PM
zeekracing's Avatar
Default 106 lsa
.239/.251 .570/.570 106lsa I was running this cam for a long time when I had my heads and headers before I blew the motor. It ran awsome. Now I have stock heads and exhuast manifolds. The car would barly run with that cam in it. I tried to tune it and had no luck, pulled it out and put stock cam back in. Has anyone else ran this kind of cam? What do yaw think about it?
Old May 12, 2007 | 10:18 PM
rons 00z's Avatar
what kind of power and times did you pull with that cam?
Old May 12, 2007 | 10:23 PM
zeekracing's Avatar
never made it to the track or dyno but from racing on the street I was keeping up with guys running 402s with cam and heads. My motor was as listed in sig. It pulled really hard all the way till about 6600rpm
Old May 12, 2007 | 11:51 PM
DONAIMIAN's Avatar
FYI the grand am cup cam is was a 239/251, not a 238/245.
Anyways, I couldnt see it being any fun to tune with an A4. What was the idle set at?
Old May 12, 2007 | 11:53 PM
Tainted's Avatar
holy **** a 106lsa
Old May 13, 2007 | 08:56 AM
Patrick G's Avatar
LS1 Tech Administrator
A cam with that much overlap demands an extremely good flowing exhaust. It will not tolerate back pressure and this would cause serious reversion into the intake manifold and kill power. Long tube headers with high velocity merge collectors, 18" open header entensions or a well designed header-back exhaust are needed to extract the most power from this cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 13, 2007 | 09:38 AM
zeekracing's Avatar
thanks for the correction my memory aint the greatest i'll edit it so it will be right. the idle was about 1050
Old May 14, 2007 | 11:12 AM
MonkeyBoneSS's Avatar
do you have any vid clips of your cam by chance?
Old May 14, 2007 | 12:05 PM
Sharpe's Avatar
I love it when you talk dirty.
Old May 18, 2007 | 09:56 PM
drain89's Avatar
Zeek it sounds like you have the grand am cup cam. Do you want to sell it?
Old May 19, 2007 | 01:45 AM
the_merv's Avatar
Veteran: Air Force
106 LSA... ****...
That thing had to lope like crazy...
Old May 19, 2007 | 12:20 PM
GR33N GoblinM6's Avatar
just get the Harrop ITB system.. and you can run that with minimal issues..
Old May 20, 2007 | 03:53 AM
cowboysfan's Avatar
werd!!!!!!!
Old Aug 31, 2007 | 06:04 PM
DVCrazyCamTAWs6's Avatar
I've got this cam.
Specs -
LQ9 6.0L
Grand Am CAM
upgraded valvetrain - Ls6/Comp
fuel system upgrade - 70psi external
Injectors - 56lbs
SLP Equal lengths Headers
3in Y to a 3in XR1 12in Borla thats sits right after the Y
MSD SC
160d stat
all the other typical MODS
100-150shot of juice (never really needed it just made things funnier)
and an S-Trim Vortech in the back seat
Full Spherical Suspension
3.73 gears
conversions
4l65e HD 4400 Yank - Awesome converter
to
T56
LS1edit tuning - Turner (Me)
pulls less then 10 vac at idle
and boost 1 psi at WOT
i've had it idling at 800 with the stock A4 with no stalling
just wants to pull through the brakes.
Vids in the sig
Old Sep 3, 2007 | 07:40 PM
RE AND CHERYL's Avatar
Originally Posted by the_merv
106 LSA... ****...
Either that or it would stall between cylinders at RPMs under 1200RPM.
