853 head to flycut when using 243 heads
Old May 17, 2007 | 05:32 PM
Xtnct00WS6's Avatar
Default 853 head to flycut when using 243 heads
Can anyone confirm that I'll be okay using a 853 head to flycut my pistons when I'll be using 243 heads? They have the same valve angle and everything right?
Thanks!
Old May 17, 2007 | 06:09 PM
onebadZ28's Avatar
I to would like to know this.
Old May 17, 2007 | 10:25 PM
Xtnct00WS6's Avatar
I'm thinking that the 243, 241, and 853 all have the same valve angles. I guess I'll just have to test it with a piece of clay. Someones tested this before though I hope....
Old May 18, 2007 | 01:27 PM
onebadZ28's Avatar
post up the results when you are finished testing because i'm very interested in the subject as well
Old May 18, 2007 | 05:23 PM
Marc 85Z28's Avatar
All 4.8, 5.3, 5.7, and 6.0 heads have the same basic geometry. I used a different casting cylinder head for flycutting than what I am running on my engine. No problems.
Old May 19, 2007 | 01:43 AM
Studytime's Avatar
Ditto on what Marc just posted. You could use an iron 6.0l head or a 806 head from a '98 car.
Old May 19, 2007 | 05:53 PM
Xtnct00WS6's Avatar
Phew....thanks guys! Just wanted to make sure
I'm going to test it anyways cause I'm a picky SOB haha
Old May 19, 2007 | 06:50 PM
RGKSR's Avatar
Default Rocker Pedestal = same
The rocker pedestal is the same for all the LS1/6 heads. This would make valve spacing the same.
L92's are different, with the 2.16 intake valve.
Bob K.
Old May 19, 2007 | 07:56 PM
onebadZ28's Avatar
I'm glad to hear this now i can just use my stock 98 heads to do the flycutting i need for my livernois ls6 heads.
Old May 19, 2007 | 09:51 PM
ss2000's Avatar
I used an 853 head when I flycut for my TSP stage 2.5 243's. no problems.
