Can you reuse stock main bolts?
Don't know what to tell you, except those are the part numbers in my 98-02 F-body parts catalog. When I received them they matched what we removed from the old engine.
I'd stick the ARP or Katech rod bolts in there at the same time as added insurance at higher RPM's. Unless you're pushing over 700rwhp, I think you'll do OK with OEM main caps & bolts. Higher than that you may want to consider ARP main studs and the Katech main caps.
