View Poll Results: To Mill or not to Mill?
Swap cam only, leave heads/gaskets alone
2
11.11%
Swap cam, run thinner gasket, leave heads alone
6
33.33%
Swap cam, mill heads, run stock gasket
5
27.78%
Swap cam, mill heads, run thinner gasket
3
16.67%
Leave the set up alone/other ideas?
2
11.11%
Voters: 18. You may not vote on this poll
To MILL or not to MILL, that is the question...
Old May 21, 2007 | 07:28 AM
erikthegoalie's Avatar
Question To MILL or not to MILL, that is the question...
I have the newer PRC Stage 2.5 5.3L (62.5 cc) heads as some of you may already know. I also run the MS3 cam on a 113 LSA, stock gaskets.
Combo made numbers in sig...HP is nice, but torque is a bit low. I decided to keep the heads. I am going to swap cams to something a little tamer with a more useable powerband for the street, something along the lines of a 228/232 112 (or 110 +2 like Pat G suggests to many people), G5X1, etcetc.
My poll is intended to get some feedback on whether or not I should mill the heads, run a thinner gasket, flycut, etc to get all my $'s worth out of the heads/cam combo.
I like the idea of just swapping the cam, it certainly easier, but if I can make the power I am making now, PLUS 400+ rwtq with the smaller cam, the money and time spent would be worth it to me...
I don't want this to neccesarily become a $ to power ratio poll, but I guess it is a factor.
Choose one of the options, and state your case.
The other helpful factor would be to suggest a cc to mill to, and a desired gasket thickness as well...Oh yeah, I only want to run pump gas, 93 octane.
THANKS!
Old May 21, 2007 | 08:18 AM
PREDATOR-Z's Avatar
mill, flycut and run a MS4 on 110
Old May 21, 2007 | 09:29 AM
Hey Pred....I thought about the MS4, since a lot of people claim the power band is better than its older brother, the MS3.....but isn't the MS4 still a hog of a camshaft?
I was looking for something more streetable...isn't the MS4 defeating that purpose, or no? I bet the peak power and torque with that cam and milled heads would be OUT OF THIS WORLD!!
Old May 21, 2007 | 11:02 AM
BOWTIE's Avatar
This sounds an awful lot like the suggestion I made in one of your post weeks/months ago. If you do not want to flycut, then I think you should go with a cam very similar to what you listed (228/232, you know what i chose) and .040 gaskets. You would not want to mill your heads with that cam because I think it would put your DCR over the top. However, if you did mill the heads then you would want to go with a larger cam (like the MS4 or even your old MS3) but you would need to flycut. I do not remember if you ever posted your ICL, but I would suspect if you reused your cam you would want to advance it 4-6 degrees, but i would check with Pred, Pat to get there recommendations as they have much more experience with this than I do
Old May 21, 2007 | 11:16 AM
Hey bud,
I remember your suggestion...hell I have had a lot of ideas thrown at me...I am just posting to get some thoughts from others...
All of you guys are a HUGE help!
Thanks
Old May 21, 2007 | 11:47 AM
MPHmotorsports's Avatar
I would buy a set of trick flows, or ETP's, run around 11.5:1 compression without flycuting and run a slightly smaller cam if your not happy about the driveability.
The 228/232 is a good cam. I would do something along the line of a TRak or Torquer 3 myself. I personially believe there is some nice gains out of the aftermarket heads.
Not having to flycut is also a nice feature.
My suggestion.....
ETP 215 59cc heads. a Torque 3 or similar camshaft. Ported 90mm intake with a stock gasket. On the same dyno you made you numbers on another camaro with the 59cc ETP 215's, Torque 3 and non ported Fast 90 made 470 HP and 440 TQ.
THIS WAS THROUGH A stock 10 both just so your know.
But that is great power, and with a ported fast you could be in the same power range with the 12 bolt you have.
Old May 21, 2007 | 12:18 PM
BOWTIE's Avatar
My suggestion.....
Do you know what head gaskets that guy was using? If he was using anything thinner than stock then his DCR was considerably higher than Erik's. I would gamble to say if Erik's DCR was up around 8.7 he would make those numbers as well with a set of heads 1/2 the price. Unfortuneatly he would have to flycut to get his DCR up that high with his existing camshaft. I am not knocking the aftermarket heads at all, but he already has a nice set of ported stock castings that will net numbers fairly damn close..
Old May 21, 2007 | 01:10 PM
PREDATOR-Z's Avatar
Other scenario,
a reverse split cam with a tight LSA like 232/228 110-1 LSA and a slight mill (PTV allowing)
Old May 21, 2007 | 02:02 PM
Nautilus's Avatar
Subscribing...
We are going to end up with the same setup...lol
Old May 21, 2007 | 02:57 PM
Hey Tim, tell me about it...keep me posted...there are SO many dam options...
Old May 21, 2007 | 02:59 PM
I just read a post of a guy who is going to run an MS4 on a 110 +4....that sounds SICK...and I think even though it is a LARGE cam, something I was considering getting away from, the 110+4 may bring the powerband in a lot sooner...
Anythoughts Guru's on a cam like that?
Old May 21, 2007 | 03:18 PM
MARKSZ71's Avatar
i wouldnt touch it spend the rest on suspension
Old May 21, 2007 | 03:27 PM
I have all suspension done, since '05...minus torque arm, which I will get when I order my rear
Old May 21, 2007 | 04:56 PM
Marc 85Z28's Avatar
Do it! I was a little concerned about the driveability of my setup, but its worlds better than my old GTP heads/cam setup. More power everywhere, improved throttle response, and the cam just does not stop pulling. I haven't had it tuned yet, but I seriously think once tuned this car will go 10s at 3700lbs on 346" and N/A!! The only downside is that you will need to flycut.
Old May 21, 2007 | 05:07 PM
BOWTIE's Avatar
Flycut, Flycut, Flycut...
If you are thinking of the one I think you are, he has aftermarket pistons with valve reliefs.
Old May 21, 2007 | 05:11 PM
BOWTIE's Avatar
Originally Posted by PREDATOR-Z
Other scenario,
I was under the impression these rev split cams really only worked well with stock type heads and intakes. He has the 2.5 5.3's with the 2.02 intake valve and a ported FAST 90/90. I would have thought he would be better off witha more traditional split.
Old May 21, 2007 | 06:38 PM
I know I would have to flycut...I dont give a ****...
I want to learn how to anyway ya know...
Old May 22, 2007 | 01:19 AM
PREDATOR-Z's Avatar
It is not a matter of working better, it is a matter of valve events. One has to have the right valve events to produce a certain power range and amount at said range.
The VEs of a Reverse will produce more trq, of course this comes at the cost of acertain amount of peak HP.
Even the 90/90 is a restriction (by design) as to how much air can be sucked in through it. That is why sheet metal intakes exist.
Old May 22, 2007 | 06:29 AM
slow trap's Avatar
i think the ms4 or similar lsk intake / xer exhaust lobe on something like a 110 will net you some nice midrange and low end gains while picking up alittle hp also. flycut and get some .040 gaskets and run the numbers scr/dcr wise and mill acordingly to get up over 8:5 dcr and it should be a sweet setup and not have to spin the motor as high as you do right now.
Old May 22, 2007 | 07:52 AM
c0ncEpT's Avatar
I say cut back on costs by just getting .040 gaskets. Than use the extra $$ for some n2o
