Metal in the oil? Anyone know?
Old May 23, 2007 | 12:41 PM
juiced_lt1's Avatar
Default Metal in the oil? Anyone know?
I bought a 2000 ss about 3 months ago ith basically boltons and a mid size cam. The mods were installed about 3k-8k miles ago by the previous owner.
When I picked up the car, it had a fresh oil change, everything looked fine, but I didn't really look extra close at it. I checked the oil when I got home (after about a 75 mile drive) and I could see small shiny metallic flakes in the oil that I wiped from the dipstick. I re-dipped it, and out came a few more metallic flakes. An old man with far-sighted eyes may have missed this, but I can see them pretty well. They are made of iron or steel, because they are attracted to magnets. Now after 250 miles, they are still in there, obviously not getting picked up the oil filter, or something is continuing to wear funny.
The car has excellent oil pressure, 50-60psi @ idle when cold, 38-40psi @ idle fully warm, and 55-60psi @ WOT fully warm.
I am going to drain the oil tonight to see how much metal I'm dealing with, but is this even normal?
Old May 23, 2007 | 12:44 PM
bjamick's Avatar
Hmm Prob just normal and your just freaking out over it.. Change the oil and inspect it and see if there is ALOT of noticeable metal shavings or something like that..
Old May 23, 2007 | 01:33 PM
BIG_MIKE2005's Avatar
It is not normal. You should never see metallic flakes in your oil. There is a problem somewhere that needs to be addressed soon. My car has almost 97k miles & has never had any metallic material in the oil & neither has anyone else I know unless there was a problem.
Old May 23, 2007 | 01:50 PM
Thule's Avatar
yeah i agree with big_mike, metal inthe oil is not normal or aceptable,
it means that somthing is be eaten up in your motor..
Old May 23, 2007 | 02:12 PM
NC98Z's Avatar
I would buy one of thoses magnetic wraps for the oil filter and at least try to get the most of the metal out of the oil. After you change the oil again you can get a better idea of how much metals getting in there.The thing I'm talking about look about like a beer can cooler and it wraps around your oil filter and is magnetic to trap the metal. Their reusable too!
Old May 23, 2007 | 04:59 PM
juiced_lt1's Avatar
Well, I'll be changing the oil today, so I guess that should tell me something... Worst case scenario I have to build a new motor... needs a trans rebuild too, as well as little exhaust rerouting.
Old May 23, 2007 | 05:51 PM
chromeplated500's Avatar
I would pull the filter off and cut around the top check that and your oil with a magnet. I had my engine do that last week.. and not to get you pissed off just yet but I ruined all my lifters and chewed my cam, havent seen my crank yet.
but good luck.
Old May 23, 2007 | 10:50 PM
staringback05's Avatar
this is why i tell everyone to check the oil pan when buying used cars, id go with a bearing material....
Old May 24, 2007 | 01:45 AM
SLP4CamaroSS's Avatar
i found metal in my oil and then i took the cam out and one the the lobe was half gone. looked like powder on the drain plug.
Old May 24, 2007 | 01:48 AM
USUALLY.....when there are very fine amounts of metal, like a paste or very small flecks, the problem has been ongoing.....if theres bigger chunks it usually means something traumatic has happened pretty fast
Old May 24, 2007 | 04:15 AM
cowboysfan's Avatar
previous owner mentioned if he was spraying? or do you even know the owner. whatever, you need to clean oil and hopefully something can be fixed quick. worse scenero, new engine...
Old May 24, 2007 | 09:22 AM
juiced_lt1's Avatar
I changed the oil last night and checked the drain plug. Looked like a fine metallic powder all over the tip of the drain plug, and one long sliver sitting in the grooves of the plug. My next step is to cut open the filter and see whats in there, should be able to do that this afternoon.
About the nitrous, he said he never sprayed it.
See if this plan makes sense:
Pull the valve covers and see if theres anything obvious under there, like a bent pushrod or broken valve spring. If not, do a compression test to make sure I'm working with a good motor. If that checks out, pull the cam, heads, and lifters. Replace cam and lifters if bad, then get the heads milled to ~11:1 and get some minor port work if cheap. Maybe $800 for everything?
Old May 24, 2007 | 11:02 AM
LS1-450's Avatar
You're on the right track. Remove the oil filler cap w/ engine running. If She's blowing oily air out of the filler cap, you won't need the compression check.
Old May 24, 2007 | 11:36 AM
juiced_lt1's Avatar
thanks for the tip ls1-450... I'll try that tonight...
Old May 24, 2007 | 04:31 PM
lt1_fool's Avatar
Old May 24, 2007 | 04:57 PM
Mike94ZLT1's Avatar
That plan makes no sense at all. A bent pushrod or a broken valve spring will cause the engine to run funny, and you said it runs fine. They also will not make the oil appear to have powdered metal in it. A compression test won't tell you if you're slowly eating a cam bearing or a crank bearing or a rod journal or anything like that. So then you're gonna pull the heads and cam and lifters, put some money into it, replace some gaskets, put it back together and have it seize up after 30 miles because it turns out it was a rod bearing, and have it be $3500+ for a new motor AFTER spending $800 on all that other ****.
Old May 24, 2007 | 05:22 PM
juiced_lt1's Avatar
Well, if the cam, lifters, cam bearings, etc etc ARE good, then the next obvious place to check would be the bottom end. I might as well get those things freshened up while they are off though.
I took it to a local speed shop this afternoon and had them listen to the motor. They said the only noise they hear is normal valvetrain noise for a cam this size and a small header/exhaust leak. I'm bringing them my old oil filter to cut open, hopefully that will tell me more...
Old May 25, 2007 | 07:42 AM
juiced_lt1's Avatar
Well, I ended up cutting that old filter open myself, couldn't take the suspense of waiting till today. I expected to see LOTS of glitter. Instead I saw, well, not much of anything, just a little bit of black specs (carbon most likely), but no visible 'glitter', or at least if there was some, I couldn't tell.
Maybe nothing is really wrong, and the light film of metal on the tip of the drain plug meant nothing, and the little glitter things that used to be on the end of the oil stick was a fluke. That would make my day.
Old May 25, 2007 | 10:33 AM
Mike94ZLT1's Avatar
I'd still keep an eye on it
Old May 26, 2007 | 12:01 AM
juiced_lt1's Avatar
Drove it 350 miles today, oil pressure perfect, drove really well. Valve covers coming off tomorrow afternoon...
