Want a Powerful but Safe Cam
I'm a newbie to all of this internal engine stuff, but I'm interested in learning what's out there as far as cams are concerned.
At this point, I'm interested in a cam that will provide a nice power gain (45 RWHP+) on stock heads without causing any excessive stress on the valve and drive trains, preferably with a stock-like idle. Basically, I want it nearly indistinguishable from stock in all aspects.
Which cam would you all pick for such an application on a six-speed car with all the bolt-ons?
Thanks,
Josh
"I saw a HOT ROD magazine LS1 build up where they used a custom Comp 224/224 .533/.533 112, XE lobes, and they were able to get over 400 rwhp out of it and some very good 1/4 mile times. Just proves that you don't need a spring-busting high-lift cam to make power; it's more the duration that's important. This cam was a custom grind, but Comp does custom grinds for no extra charge and only about 4 days extra time."
I'm goin' for the ASA Cam; it has relatively low lift but with plenty of duration (easy on valve train). It will not meet your good idle requirement, but sounds badass.
dont know if itll give u 45HP but it sounds stock and can idle close to stock
some ppl call it a sleeper cam
cause it sounds stock but up top its all good
https://ls1tech.com/threads/showflat...rue#Post509072
Tommy
Tommy
If I do this, it will probably be in the next month of two, but I'm also looking at headers, I just can't decide which to do first. I know the headers seem like the more logical option, but I doubt I'll have the money to buy a cam for some time if I go with the headers, and vice-versa.
Anyway, thank you all again!
Josh
