Cam??
Old Jun 5, 2007 | 05:30 PM
02BEAST's Avatar
Default Cam??
Hey guys I am looking for a cam that will put out good gains and give me that mean sounding choppy idle it will be mostly a dd and see the track 3 or 4 times a year and also I will need to pass inspection also Thanks.
Old Jun 5, 2007 | 07:55 PM
ExceSSive's Avatar
That could be impossible to meet all those requirements.
Old Jun 5, 2007 | 08:17 PM
chavez885's Avatar
Pass inspection? HAH!
Old Jun 5, 2007 | 08:36 PM
BriancWS6's Avatar
Well first off your going to need a higher stalled converter, and the rest of your bolt-ons. I ran a 225 single pattern on a 112 lsa with a 3500 verter, and it was a nice driving and performing combo. I would suggest you get something like a TR224 on a 114, with a nice tune you can pass emissions with that.
No, it won't sound super aggressive, but compared to stock, you'll know there's a cam in there. Coupled with a nice 3500ish stall, you will feel a nice increase in performance.
Old Jun 6, 2007 | 06:29 AM
02BEAST's Avatar
I'm mainly looking for that mean choppy idleling sound and decent gains is it the lobe that produces that sound?
Old Jun 6, 2007 | 07:15 AM
teke184's Avatar
weeeellll....kindda.
it definatly adds to it.
the lower the lobe separation angle typically the choppier the idle....
BUT....the lower the LSA...the less likely you are to pass emissions. that's why he suggested the 114 on the cam over the 112.
remember the stock ls1 cam is about 119 LSA (early years) and the LS6 is about the same.
an option for the idle that you want would be to bring the idle rpm down...should make it chop a bit more...but you'll run a higher risk of stalling
Old Jun 6, 2007 | 07:27 AM
02BEAST's Avatar
Could I bring the idle down on my stock cam to get that choppy sound also?
Old Jun 6, 2007 | 10:30 AM
INMY01TA's Avatar
T Rex!
Old Jun 6, 2007 | 05:02 PM
BriancWS6's Avatar
What gives you the lope is overlap. If you have any significant amount of overlap at all, it will NOT pass emissions testing. If you get the cam I suggested, lower the idle to about 650, pull some timing out at idle, and run an open cutout or true duals with aggressive mufflers (sweet thunders, bullets, single chambers), it will have a nice sound, but still far from radical.
No, there is nothing you can do with your stock cam to make it lope, besides pulling a plug wire or two off
Old Jun 6, 2007 | 05:03 PM
lastcall190's Avatar
Pull the brake booster hose
Old Jun 6, 2007 | 05:27 PM
melchoir's Avatar
I would suggest a TR224 on a 114, you can pass emissions with that.
As mentioned before, the idle won't be radical, but the power gains should be decent.
Old Jun 6, 2007 | 06:13 PM
silverbandit0996's Avatar
that will make it chop. i made my little brother think i cammed my car when i fired it up to seafoam it.
Old Jun 6, 2007 | 06:25 PM
02BEAST's Avatar
Where is the brake booster hose?Is it safe?
Old Jun 6, 2007 | 07:22 PM
SmallTires's Avatar
He's joking, don't do that!
Old Jun 6, 2007 | 07:26 PM
chavez885's Avatar
LMFAO!!!!!!!!!! THAT IS GREAT!!
Old Jun 6, 2007 | 07:55 PM
Just kidding with you man, you pull it when you wanna seafoam the car, by all means don't drive around like that
-J
Old Jun 6, 2007 | 08:02 PM
02BEAST's Avatar
-J
Dam I knew something was up it didn't sound right.
