Timing chain and/or Ported Oil pump necessary?
Oil pump...you'll get varying opinions on this but this is one mod I didn't do. IMO, save the money and buy some hardened 7.4" pushrods. If you treat the o-ring on the pickup tube gently when removing the pump, (if you decide to do a chain...otherwise you don't need to screw with the tube) the stock pump should suffice. My vote? Chain, yes. Pump, no. You'll love the new cam!!
One of our club members was revving a stock chain with a B1 cam like mine to 7100rpm under boost. The motor did fail eventually, but the stock chain never broke!
I don't feel that the stock chain is all that weak, the pump I would look at replacing though. Maybe people have had stock pumps fail with stock motors and very low miles. I don't hear of any failures of stock chains on stock motors with low miles, so right there you have to figure that the pump is a more known weak point. One friend has had TWO stock pumps fail.... One of our club members was revving a stock chain with a B1 cam like mine to 7100rpm under boost. The motor did fail eventually, but the stock chain never broke!
I asked the GM dealer about a new pump, and GM had revised the part #s 2x. That was enough of an incentive to spend the 80$ on a pump. As for the timing chain and gears. Both the chain and gears looked really good at 20k miles. I swapped them anyway. The replacement chain from GM high perf is stronger than the stock one.
It is your car, and if you are ok with putting the used parts back, do it. These questions get asked about 50x a year, so there is a lot to be found with a search.
Just my .02.
