WTF is wrong with my stupid car?
#62
Not at all. Just pull the plastic and carpet back on the rear hatch deck, then carefully cut a hole... 3 sides of a square. Peel back, and VIOLA! Access to the pump very simply and easily. THere should've been an access panel there from the factory as far as I'm concerned.
#64
ok guys it finally threw a code!
P0133 02S Circuit bank1-sensor1 slow response...
Any ideas? does that mean my brand new O2 sensor is bad, or could it be the wiring harness or something...
#65
my bmw 740 had those same syndromes,
when i checked it in OBDII, i got codes for o2 sensors and cranksensor,
i think this codes is the o2,
in my case i changed both and the car was fixed,
sorry i cant help more
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#67
slow response would be a bad o2 sensor. That could be what's causing the problem. If you had a o2 low voltage code, that could also mean the sensor is bad or your car is running too lean. Your car is tuned with a Predator right? I don't think that could make your car run too lean though. Did you try using the stock tune to see if the problem would go away?
