Comp Cams 918 spring broke......
Isn't Comp a sponsor of this site? Have they responded to any of the other broken spring threads on here?
If you look into the math, I believe they usually calculate the mass of the spring/retainer into the equation at about 1/3 the actual mass of the spring/retainer. So you figure in the double springs and bigger/heavier retainers and now you're back to square one, if that!
Why do we (vendors in general) always encourage people to run titanium retainers on their 918's and other beehives??? And then why are so many people so quick to recommend a double spring when it's not needed?
I'd just assume see more people purchasing a slightly heavier 3/8" pushrod than the standard 5/16" ones....at least there the extra weight is put to good use! But again, I never see anyone on here recommending those to the average Joe.
Just my $.02 to get people to "think outside the box." I've e-mail our rep at Comp this and the other link so maybe we can get him or someone on-board to shed some light on this subject!
I am a Technical Service Engineer for USS and will be dropping off some samples for testing (customer concerns) on Monday 6/11/06. At that time I consult with our manager of the Metallurgical Lab and request that a full micro and hardness analysis be conducted on my broken spring. If he allows the work to be done, I should have a technical report available by the following week. Hopefully, I will have something to report to you guys by them.
PS. I always use titanium retainers on my springs.
Comp or the spring manufacture are consider to be not at fault until scientific evidence is available. There is still a possiblity that the failures are related to other factors and not necessarily to a defective spring. Lets just keep our pants on until I have some valid answers.
Just another question: Are all of the broken 918 springs from applications that use Comp camshafts? If so, which lobes are you guys using that are experiencing failures. The reason I ask is because the springs may be alright, but if the lobes are of poor quality or too aggressive for the spring, the springs will be over loaded. Keep in mind that their's more to the system than just the spring.
mine too.....I believe all of the newer 918s are blue stripe for awhile now, likely BEFORE the manufacturing change.
It's clear that a particular 918 can't be considered suspect just because it's a blue stripe for this reason. HOWEVER, my springs were purchased LAST JULY, while some of my friends who have had failures have springs that are only a couple months old.
In short, i'm personally suspicious of any 918s manufactured after mine...
my cam is a 224/224 with only .567" of lift ON AN XE LOBE.....
I'd like to see them explain that....
also I checked around the basement and found my stock springs in the Comp box so, I'VE FOUND MY BATCH NUMBER!!!!
Make this one official spring failure from batch # 49253.
Please post it up in my new thread on LS1GTO, i'm trying to get a list going.
I also don't have the time to wait for different springs, this makes me really angry.
