Comp Cams 918 spring broke......
thing is, its a friends T/A we are doing the work on as a SURPRISE! I DO NOT WANT a valve to drop because of these shitass springs then he disowns me forever!
E
Take that for what it's worth. It's my opinion that the springs are not breaking simply because of too much cam.
I have gotten on it many times before it was completely warmed up (although I live in Phoenix so my engine is usually at least a hundred degrees before I even turn the key) and the springs probably have at least 50 1/4 mile runs on them.
No problems at all!
Steve
Got that stroker done yet?
I can't believe the posts that say, "the old Comp 918 springs were great and never had issues." I'm not here to flame Comp, but this simply is NOT true.
Since the begining from 2002 or so, these springs have had lots of breakage issues. My H/C swap is 5 years old now. When I was scouting parts for my work, the 918 was the hot set up. Unfortunately, people were reporting a high incidence of breakage with little or no customer support.
I went with doubles and never looked back!
I have all my gaskets and bolts gathered, ordered a Patriot Gold dual spring kit and am picking my head up tomorrow from the machine shop where I had it checked and new valve installed. It'll go back together Friday when I get back to Georgetown.
Hopefully we can get all of this worked out with Comp or at the very least make the problem known so that people take the extra precautions in avoiding further occurances like ours. Sorry if any of my posts seemed dick-ish on here also.
But I agree, go duals and sleep soundly...
Pictures of the carnage:
This is a sparkplug
Note the Rod. Also block and head are cracked. Only thing slavageable was one head the rest was history.
Note the connecting rod and the valve stem. Also block and head are cracked. Only thing salvageable was one head the rest was history.
This was from a broken 918 spring with my car only going 70 mph, this past weekend. The cam I had/have is a C cam or Torquer 2 whatever you wanna call it with approx 5-8k on the cam since install. I have now upgraded to PRC Springs and rods oh and lets not forget a new engine.
And please this post is not to be a bashing but it should hopefully clear the air as to some peoples interpretation on a safe/quality spring. Oh and the good people at Comp said they would send me a new set free once they determine that the spring was faulty. These will be in the for sale section when I get them.
There hasbeen several reported failures under that batch number
Looks like ill be pulling my valve covers to see if there is any
broken ...
