Comp Cams 918 spring broke......
Old Jun 11, 2007 | 01:00 PM
  #81
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Ok guys, I just got off the phone with CompCams and they want to be involved...here's what they/we need from the members here:
If you have any of these broken springs, CompCams wants and needs to talk directly to you! They also of course will want these springs back so they can test them and look into this.
it is VERY difficult (if not impossible) for them to remedy any problems there might be with a spring by reading about it on the internet! So please, call CompCams at 800.999.0853 (that's their toll free tech line), and tell them you've got broken spring(s) and want to know what to do with them! Their customer service is second to none and they want to speak to you! Again, the only way they can fix a problem that might exist is to deal directly with the customer with the springs!!!
Thanks!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jun 11, 2007 | 02:24 PM
  #82
jimmypop13's Avatar
I can't believe this is happening guys! I ran 918s in my car with a TR230 cam for 4 years & 50k miles and never had any of them chip or crack or fail. I hope Comp can get you guys back on your feet ASAP!
Old Jun 11, 2007 | 02:29 PM
  #83
GuitsBoy's Avatar
Many people did run these sucessfully for years. They made a name for themselves as one of the highest quality springs around. Then it seems comp switched a magic ingredient and one or more batches went to ****. Very curious about how theyll take care of their customers.
Old Jun 11, 2007 | 03:57 PM
  #84
Reckless's Avatar
Super Moderator
To echo Matt....I too talked with Comp about the issue. They recommend sending any broken parts back for inspection.
If you look at our web site, particularly our cam packages, we do not even offer that spring on the cam packages with anything over .569 lift.
After that, we offer only double springs in the packages.
IMO, this is mostly a "kneejerk" reaction to a few broken springs. I have seen every spring out there break at one time or another. It is the nature of what we are doing. We are pushing parts hard and these cars make more than any muscle car ever did from the 1960's or '70s.
Also, Thunder has had ZERO cals regarding the 918 springs, and I believe this is because we do not sell it to folks running cam lifts over .570". Not pciking on anyone else, but you can get a good deal on parts, or you can get what you need with no "ragged edge" worries required on your end.
Old Jun 11, 2007 | 04:00 PM
  #85
Couldn't have said it better myself, Todd! Thank you.
__________________
Old Jun 11, 2007 | 04:10 PM
  #86
Evans's Avatar
Thanks!
I just got off of the phone with Comp and no one that I spoke to (several different people) had a clue about any of this. All but one didn't even know what a vavle spring was! I was told that they were unaware of any 918 failures but would like me to send all my springs back for them to check out. He also stated that I MAY be sent another set of springs to replace mine. I told the rep that I did not want another set as I just ordered Patriots from Thunder Racing a couple of hours ago. I'll update when I know more.
Old Jun 11, 2007 | 04:20 PM
  #87
GuitsBoy's Avatar
I wouldnt replace them with more 918's unless comp has detected a problem. These springs went practically for years without hardly any complaints. Now all of a sudden it almost seems like everyone who installed these within the last years is popping their valve covers only to see the spring ends broken off.
Heres a link to another couple instances local to me. (Thread title may be NSFW)
http://www.fastlsx.com/forums/showthread.php?t=14859
Snuff Pics: http://www.fastlsx.com/forums/showpo...7&postcount=29
This guy was a big topic of conversation at dyno day (since he missed it) and a few additional local instances were noted.
Old Jun 11, 2007 | 04:21 PM
  #88
Red in warranty claims is the man to talk to! Leave him a message if he doesn't answer and he will return your call! he knows the situation and is ready for your calls!
__________________
Old Jun 11, 2007 | 04:25 PM
  #89
BYE RICE's Avatar
+1.
He helped me out.
The "tech" guys are mostly worthless.
It's like they went down to the rescue mission & hired Tyrone Biggums.
Old Jun 11, 2007 | 04:27 PM
  #90
GuitsBoy's Avatar
< Dave Chappelle > If youre watching this video, then youve recently been hired to work at Popular Copy... < / Chappelle >
Old Jun 11, 2007 | 04:29 PM
  #91
66deuce's Avatar
Originally Posted by vettenuts
The 120# @1.800" is simply a rating. There is probably no one on this forum running springs at 1.800", not even the stock springs are set up at that height, they come it at about 1.760".
really?when i had LPE go over my heads on my old Z,the springs checked out at 135lbs@1.800" installed height..they were the Patriot Gold Duals tho,not the 918s..
i wonder if some shops just put them in without checking pressures,assuming if they install them at 1.800" all is well...
Old Jun 11, 2007 | 04:37 PM
  #92
GuitsBoy's Avatar
I think he meant that the 120# @ 1.8 is a rating. You can change your seat pressure by shimming, or effectively reducing the install height. Thats how you would run a more aggressive cam without valve float, within reason. If you shim too much, you have to worry about coil bind. You would install at the normal 1.8 unless it was a specific application that required additional pressure.
All of the 918 springs should measure the same. You should not have to shim differently to get to the target seat pressure.
Old Jun 11, 2007 | 05:06 PM
  #93
66deuce's Avatar
..i took it to mean that some springs have to be shimmed a little to get the rated seat pressures,ie to get 120lbs he had to shim them a little bit,and reduced the installed height below 1.800"
Old Jun 11, 2007 | 05:41 PM
  #94
david vericker's Avatar
This is a kneejerk reaction to a few broken springs?? Please, just how dumb do you really think the people on this tread are. A response like that is BS. Comp states that the 918 springs are good for 600 lift. MY springs had 3500 miles on them at 580 lift using all Comp Cam compoents
I will have test results on my broken spring in about a week.
Old Jun 11, 2007 | 05:53 PM
  #95
pm supra's Avatar
I have set of 918's w/retainers NIB and a set of 921's NIB, ordered both because I couldn't decide on which. I am sending them both back, ordered a set of Patriot Golds.
Old Jun 11, 2007 | 06:10 PM
  #96
Reckless's Avatar
Super Moderator
Understandable Dave, but 5 broken springs out of 80,000 is a pretty good success rate
Got that stroker done yet?
Old Jun 11, 2007 | 06:22 PM
  #97
GuitsBoy's Avatar
I understand what you mean here, but i count more than 5 people out of my local club of 100 cars. Ive seen the 918s go past 30K, 40K even 50K in the past, but now these are breaking after a few K miles. Something has changed. The springs are not what they used to be.
Old Jun 11, 2007 | 07:18 PM
  #98
Fibbado's Avatar
Thats is a good success rate, but it is unnerving none the less. And the uncertainty is enough to deter some from using them. I just went ahead for the patriot duals package and I'm not gonna look back.
Old Jun 11, 2007 | 09:55 PM
  #99
hvactech's Avatar
Thanks for the heads up Evans,just pulled my valve covers and see 4 broken.
Batch # 49826 200 miles on Torquer v.2
Old Jun 12, 2007 | 01:32 AM
  #100
Justin00SS's Avatar
I just don't see how you guys are breaking springs 200 miles or so after installing a cam.
It says in the "cam guide" here to allow a ~300 mile or so break in for the springs so they get some heat cycles.
Are you guys installing a cam and then beating the **** out of your car and banging the redline? Comp cams has been around for a long *** time and I've never heard of this and I've had a hand in the 3 drag cars.
