Torquer V3 vs. Torquer V2
Old Jun 10, 2007 | 03:32 AM
mudflap1989's Avatar
Default Torquer V3 vs. Torquer V2
How much does the LSK lobe on the intake really help, I know that it slighty increases DCR and I guess it allows a little more flow, but how much hp are we really talking.
Also what LSA and ICL should I order either one of these cams on? This will be for a 03 Z06, LS6 intake, kooks 1 3/4" headers, pulley, varaam intake, stock gears.
Old Jun 10, 2007 | 12:03 PM
onebadZ28's Avatar
The Torquer V3 gets my vote on this one. If i were you i would get it on a 111LSA the ICL is 110 the cam has 1 degree of avance ground into it. Not sure about the difference the lobes make but the torquer V3 uses LSK lobes on the intake and XE-R lobes on the exhaust. Just a little information you might find useful one day
Old Jun 11, 2007 | 09:31 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I'd say the T3 makes 4-5 hp more than the t2. The T3 definately comes in a little bit earlier & makes great power! Hope that helps!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
