Got a idle issue...
Old Jun 13, 2007 | 03:12 AM
staringback05's Avatar
Default Got a idle issue...
when i come to stop lights and the car stops the idle and oil pressure drop down pretty low id say 200-300 rpms....my car idles normally at 500rpms....
there are no air leaks or exhaust leaks....voltage is good
oil psi hot at idle is around 33 and close to 60 on the highway....
however at a stop the oil needle ticks slightly, ive had spunning bearings before but i had alot less oil pressure to....
i think the rpm level bothers me a little more, could this be in the tune? if so what parts of the tune would this be under?
Old Jun 13, 2007 | 07:59 AM
Superjoe's Avatar
Well for starters there is the desired idle speed which is programmed into the computer. It's as simple as punching in the three digits. But there are also the idle air counts and the a/c desired idle speed. ( don't quote me on any of the names). Getting those all to work together is challenging, especially after a cam. Have you recently done a lot of mods without getting it tuned?
Until you get it tuned you should crack the throttle body blade a little using the adjustment screw to bring the idle up (don't drill the blade). 500 rpms is too low in my opinion, should be above 750rpms.
Old Jun 13, 2007 | 08:51 AM
TheLS1Kid's Avatar
Could be the TPS sensor.
Put a new one on and if it doesn't fix it, return it and say you didn't need it.
Old Jun 13, 2007 | 08:52 AM
GuitsBoy's Avatar
youre idle airflow is not dialed in. Most likely the RAF table needs tweaking and theres a big idle air trim factor thats screwing things up.
Old Jun 13, 2007 | 04:14 PM
^^^i was leaning towards this but im not the one with efi live
the sensors are fine, and my A4 has always idled around 500...car doesnt have ac, full bolt ons and was recently tuned...i guess thats the issue, just wanted to see if these could have been symptoms of anything else....thanks
