Texas Speed (PRC) 5.3L stage 2.5 heads -- what cam?
#41
Anyone have opinions/numbers with these cams:
- Texas Speed Torquer v2 - 232/234 - .595/.598 - 112 LSA
- Texas Speed Torquer v3 - 231/234 - .643"/.598" - 112 LSA
- Texas Speed XS Series - 233/239 - .595"/.603" - 112 LSA
- Texas Speed Magic Stick v3 - 237/242 - .603/.609" - 112 LSA
- Texas Speed Magic Stick v4 - 239/242 - .649"/.609" - 112 LSa
I will be calling Jon early this coming week about all the parts selection.
#43
Originally Posted by jimmypop13
Ms3 Imho
#45
My stage 2.5's came in at 65.8cc.I'm not sure how that happend.
I ran a 233/239 cam..That cam is for sale..I will be running a cam somewhere between an Ms3 & MS4 custom grind..For an off the shelf cam..MS4' work really well..You need 4.10s & a competent tuner to make it work.
I have a friend that runs an MS4 in his CETA..I works really well with his LS6 long block.
#46
Originally Posted by studderin
were did you hear hellion need flycut? It dosn't, and theres a lot of locals running around on there stock heads that havn't been off. You should cheak there cars out and see if its for you.
- camshaft - $380 (TSP) / $450 (Hellion)
- hardened pushrods, double valve springs (seats, seals included), titanium retainers - $380
- timing chain - $36 / $130
- ported ls6 oil pimp - $140
- new gaskets - $50
- dyno tune - $275
- fuel injectors - $300
- fuel pump - $100
[Note: my numbers may be a little off as these are just estimates from one LS1TECH sponsor]
However if I go with heads and cam install then I may want to stick with all Texas Speed parts so that they can cut me a great deal (looking at about $2700+ in parts w/out install).
#47
Originally Posted by venom ws7
Go with MS3 and the PRC 5.3 Heads this combo is the best combo or go with
Torquer 3.
T-rex ,MS4 and the Hellion Great cams but you need to flycut the pistons with 5.3 heads cuz the 63cc
I would talk to Jason or Trevor at TSP they will help you alot.
Torquer 3.
#48
Originally Posted by voda1
Anyone have the flow numbers for the 2.5 5.3l heads? I've seen the intake numbers on their web sit. Interested in the .200 intake number and exhaust numbers.
#49
Does anyone know if New Era does Speed Density (SD) tunes? I know they have HP Tuners software and a tune is $275, but can they do SD?
There is also a place called Eksten (sp?) Autoworks in Rochester, NY that tunes F-Bodies. Anybody had any experience with their tuning? Do they do SD tuning?
How about Kennedy's in Rochester, NY (or near Rochester, I can't remember off the top of my head). Any experience with a tune from them? Do they do SD tuning?
Any other places around Rochester, NY and the surrounding areas that I haven't mentioned above? Thanks guys.
#50
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
#51
Also what sized injectors would be ideal for this heads/cam buildup? I have seen people run 42lb. injectors, but will 30lb. injectors be fine? This will tack on another $300-$400 to the total price. Damn it just keeps adding up. Also factor in another $100 for a Walbro 255lph Fuel Pump. Should I get this set-up: http://www.texas-speed.com/shop/item...d=682&catid=10 or just the pump itself. The voltage increasing wiring harness is $100 more. Is it worth it?
#52
What should the new rev limiter be set at with either the TSP XS Series 233/239, TSP Magic Stick 3 237/242, or the New Era Performance Hellion Cam 244/248. Thanks.
#60
This is what i'm talking about 65.8cc whats this crap, mine are 67cc these are meant to be 59cc. like i said you get what you pay for.
