383 head/cam question
Old Jun 14, 2007 | 09:38 PM
Rickyh93's Avatar
Default 383 head/cam question
I have a cam that I will be putting in my 01 Z06 it is a custom grind 235/242 647/622 on a 111 icl. Would this cam work ok if I decide to go ahead and put in a stroker kit when I do my head/FAST 90 swap? Also, what heads would work well with this cam, I haven't seen many specs that list anything over .600 lift.
Thanks
Ricky
Old Jun 14, 2007 | 10:19 PM
slowride's Avatar
It seems large enough, but you would have to check your dynamic compression to make sure it's going to run ok on pump gas.
Old Jun 15, 2007 | 08:25 AM
Rickyh93's Avatar
I just checked that this morning. It is up there with the 59cc heads I was wanting to put on my 346. I could use 64cc heads on the 383 and it looks like I get 12.1 SCR and 8.975 DCR
I guess it works better with the 346 11.79 SCR and 8.68 DCR
Is 8.9 too much to run on 93 octane. I have a Shell station nearby that sells 110 I can always mix a little in if I need to.
Ricky
