thinking about putting ls6 cam and heads on my ls1
Old 06-16-2007, 08:29 PM
hnaskoct's Avatar
Default thinking about putting ls6 cam and heads on my ls1
i wanna know will i feel a nice difference,, how many extra horses will i pick up by just doin that and will i have to get m tuned...
Old 06-16-2007, 08:34 PM
02silvaZ's Avatar
you'll pick up decent power, stock LS1 is 345hp, LS6 is 405hp so you will notice a fair amount of improvement, just depends how much you are looking for
Old 06-16-2007, 08:44 PM
sidewayz28's Avatar
i highly suggest just throwing on stock ls6 heads, but going with a larger cam.. this is basically what im running except a fer more goodies..youll want more cam
Old 06-16-2007, 08:53 PM
'02 WS6's Avatar
go w/ ported ls6 (243) castings w/ a bigger cam, you'll like it better than a stock ls6 or "hot" cam
Old 06-16-2007, 11:29 PM
Camaro Rick's Avatar
Check my sig. I also strongly recommend a larger cam over the LS6. My 220/220 drives just as well as stock if not better(after tune). Might at well just go for a 224 cam at minimum while you're in there.
Old 06-16-2007, 11:32 PM
hnaskoct's Avatar
but will i need a tune for a stock ls6 cam
Old 06-17-2007, 02:16 AM
Xtnct00WS6's Avatar
Don't waste your time putting stock heads or a stock cam in your car. Do it right the first time. For budget minded people, I'd suggest Patriot Performance 243 casting heads with stock valves (no piston to valve clearance issues) milled to about 62ish cc's (maybe more) and at least a TR224 on 112. This is safe setup that should get you a little more than 400 to the ground.
Old 06-17-2007, 11:41 AM
Red00's Avatar
No, you will not.
Old 06-17-2007, 01:53 PM
mudflap1989's Avatar
In a couple of weeks I will have a stock LS6 cam/heads/pushrods etc. available for sale if you're interested. They have 0 miles on them.
Old 06-17-2007, 02:04 PM
Will you NEED a tune?
-No
It's highly suggested though. A tune can never hurt, providing that you go to a knowlegeable shop. Lots of guys on the tech drive head/cam cars untuned for great lengths of time. But the truth is - with every mod you install, there is still something left on the table without a tune.
Old 06-18-2007, 07:04 PM
hnaskoct, clean out your PM box.
Old 06-18-2007, 09:34 PM
speedy_2's Avatar
This appeals to me very much. Is this good for a daily driver as well?? What is expected in Fuel Consumption?? I think i'm going to start saving up money now!! That 400 number really makes my eyes light up!!
Old 06-18-2007, 09:36 PM
ChevyThunder17's Avatar
Expected fuel consumption is directly proportionate to your ability to keep your foot off the accelerator.
Tuning is always recommend, even if you are BONE STOCK. GM leaves some HP on the table, and if you are good you can get it back.
Old 06-18-2007, 09:42 PM
MESS's Avatar
i just bought some LS6 heads, now i'm saving up for some porting to be done and then i'll pick a cam...... get a tune no matter what, your car will run so much better and like said above, you will pick up extra horses
Old 06-18-2007, 09:56 PM
speedy_2's Avatar
Really? Never knew about that. How much power can be picked up tuning a bone stock car?? Just curious.
Old 06-18-2007, 10:11 PM
Depends on the car really. With mass production engines, it's really weird. Maybe 10, maybe 30. I know that the 4.2L in the Trailblazer has about 40 hanging around in it.
You turn off torque management, tweak the timing tables, run 93 octane. GM has two timing tables, Hi and Low. It goes between the two dynamically. So you narrow the range between the two and keep the timing up. Wa-la, instant horsepower.
Old 06-18-2007, 10:13 PM
speedy_2's Avatar
Sweet. I plan on putting the car on a dyno in two weeks. Maybe I can get a tune after that. Thanks for the info.
Old 06-18-2007, 10:14 PM
No problem. I would tell you to look into getting yourself an HP Tuners setup if you are really that into the idea.
Same goes for the original poster of this thread. Get tuned, do it yourself if you are up for it. There are plenty of resouces available to assist you.
Old 06-18-2007, 10:17 PM
speedy_2's Avatar
I'd like to. What does that HP Tuners setups consist of?? Something I would use with my laptop or is it stand alone?? Could it clear my SES code from removal of the AIR system as well?
Old 06-18-2007, 10:32 PM
The answer to your questions are the cable and software, use with your laptop, and an emphatic yes.
Check out the website.
