How hard is it to rebuild your own lsx?
Well I found out that I spun a bearing and was thinkin about rebuilding the motor myself. Any people done this? Looking for some input and pointers. I have built a 383 stroker myself but not an lsx motor before. Are there any web sites that will help walk me through this.
My plan is to keep everything the same just turn the crank and put some new bearings, probably an oil pump cause I have a feeling this is why Im in this situation. I have lunati billet rods and diamond pistons that I would like to reuse if possible. I will have the rod ends checked to make sure there not out of round.
Can you guy's think of anything else?
Is doing it myself a bad idea?
Thanks
Brian
Thanks
Brian
Looks like he is going to build the ls block he just wants to know how much different it is from building any other sbc.. I would say its just about the same. Pick up a haynes manual and they guide you through alot of it and it tells you the proper ftlbs of bolts. Just make sure you don't the cylinders don't get bored out too much. Just a hone is what you should need!
if your going through the trouble of taking it apart spend the extra money to get forged rods and pistons. even if stock compression, just having it there for later is worth the expense than doing it twice
