TFS 215 head gaskets?
Old Jun 25, 2007 | 05:24 PM
RedDemonLsX's Avatar
Default TFS 215 head gaskets?
Im expecting my TFS 215 heads this week and was wondering what gaskets to use.Do i use stock gaskets because of the ptv clearence(heads are milled to 61cc)or do i go with some cometic .40 gaskets.Also...what else as far as bolts and studs do i need to use with these heads...basicly what do i need as far as everything (gasket/head bolts) to put these heads on...thanks in advance guys
Old Jun 26, 2007 | 04:11 AM
nobody knows?
Old Jun 26, 2007 | 07:09 PM
ls2 bait's Avatar
head bolts/ studs whichever you choose. i chose arp bolts. im using a .045 cometic gasket also. quite a bit more money than the stock gaskets. you will also need a set of roller rockers as the stock ones wont work. other than that you should be golden.
Old Jun 27, 2007 | 12:07 PM
exSSer's Avatar
Yeah, if you're stick with the TQ2 cam, you can use Cometic .040 just fine. The TFs have add'l clearance. Roller rockers...... gotta have 'em. Ask me how I know.
