Heads are in
Old Jul 6, 2007 | 08:13 AM
BIG_MIKE2005's Avatar
Default Heads are in
Finally recieved my 5.3 heads from Bo White. The extra long wait was due to a error by the machine shop, but Gunnar @ Patriot was able to fix em' better than new. They are port/polished & milled .018" by Bo & were fully assembled by Gunnar with the Patriot Gold Dual spring kit. I could not be happpier with the quality of the work done by both parties & the flow numbers looked great for a stock cast head. They should compliment my 224/.581 114 cam nicely.
Old Jul 6, 2007 | 08:25 AM
RZRSEDGE's Avatar
Sweet set of heads you got there! Now throw 'em on there and let us know some results!
Old Jul 6, 2007 | 02:53 PM
Install will be happening next weekend. I will have dyno numbers Monday July 16th. We will be installing the following:
LS2 timing chain
LS7 lifters
Bo White P/P & milled 5.3 heads
Bo White P/P Lingenfelter intake
Bo White P/P TB
Thunder 7.4 chromemoly pushrods
Melling oil pump
Comp 224/.581 114 cam
And I also have a in-line Walbro pump & 36# injectors if need be.
Old Jul 6, 2007 | 03:21 PM
Bo White's Avatar
Glad they are what you were lookin for , thanx again for the opportunity to port some heads
Old Jul 6, 2007 | 05:05 PM
the_merv's Avatar
Veteran: Air Force
What are they supposed to flow?
Old Jul 7, 2007 | 01:41 AM
Okie5.3's Avatar
big_mike where are ya taking it to dyno? Ed's or Tulsa dyno? if you don't mind, might like to stop by when its on the rollers.
Old Jul 7, 2007 | 07:20 AM
Shooting for Monday July 16th, but my tuner is wanting to wait a little longer to make sure its all running ok mechanically before we strap it down.
Old Jul 7, 2007 | 07:21 AM
219 @ .600 lift on the exhaust side
261 @ .500 lift on the intake side
Bo can correct me if I'm wrong.
