cam suggestions?
Old Jul 6, 2007 | 02:04 PM
transaman98's Avatar
Default cam suggestions?
i am looking to change my cam setup. i thought i was going to be satisfied with the cam i am running but it seems that its not exactly what i was looking for. as in not enough. i dont drive the car enough to care about mileage. so what would you guys suggest for a cam swap?
currently i have a 3200 stall with stock rearend and 3.23's with a comp 224/230 .581/.592 114LSA cam. All the bolt ons...fast 90/90, hooker longtubes, etc, etc...
i would prefer not to have to change the stall but if its not possible its not possible.
anyone got any cam suggestions?
thanks.
Old Jul 6, 2007 | 02:19 PM
Kamin's Avatar
what numbers did it put down?
Old Jul 6, 2007 | 06:49 PM
never had it dyno'd. it ran pretty good but i had the car setup with driveability as the number one factor to consider. i quickly discovered that this cam drives damn near like stock and i can put up with quite a bit of loss in the driveability department.
Old Jul 7, 2007 | 03:47 PM
mrr23's Avatar
the vinci 060 would be a nice step up from what you have now
http://vincihighperformance.com/superwebdeals.HTML
i run the 099 in my 408
http://vincihighperformance.com/CAMS...%20LS1%202.htm
if you want more lift, then go for the 100
here's an idle sound clip of the 099 in my car.
http://www.stealthram.com/familypics...08/408idle.wmv
Old Jul 7, 2007 | 04:03 PM
JPH's Avatar
JPH
crane #1449601 or the vinci's #049 cam would be a step up from what you have now, and work graet with your combo. all though a cam like this, would like more stall and head work for an overall peak performance.
Old Jul 8, 2007 | 12:51 AM
1997bird's Avatar
288/296 Adv. duration
228/236 @ 0.050" dur.
.603"/.603" lift w/1.7 rockers
110 LSA
108 ICL
That gives you 12* of overlap @ 0.050" and should be able to be tuned fairly easy with a good tuner. Dual springs would be strongly reccommended for this cam.
Old Jul 8, 2007 | 09:21 AM
02silvaZ's Avatar
thanks.
well hell, just go MS4, that oughta be big enuff
Old Jul 8, 2007 | 09:43 AM
PREDATOR-Z's Avatar
thanks.
231/240 .643/.608 112+4 LSA (LSK/XE-R)
That will get you over 400rwhp cam only in a A4.
Old Jul 8, 2007 | 04:05 PM
would i need a bigger stall for the MS4??? The heads are ported 241's with Ferrea 2.02/1.57 valves, Comp 918 Springs, And Comp 1.85 Rockers. Suggest getting new heads???
