224/228 .600/.588 111+3
does it sound like a good choice for an LS1 with stock 241 heads? friend bought a 2002 z28 with slp package, and i've suggested to him to get this Comp ground:
----------------------------------- 0.006 0.050 0.200
Intake Duration ------------------- 276 224 147
Exhaust Duration - ---------------- 277 228 149
Lobe Center Angle - --------------- 111 111 111
Intake Centerline - ---------------- 108 108 108
Intake Valve opens - IVO ---------- 30 4 -34.5
Intake Valve closes - IVC ---------- 66 40 1.5
Exhaust Valve Opens - EVO -------- 72.5 48 8.5
Exhaust Valve Closes - EVC -------- 24.5 0 -39.5
Exhaust Centerline - ECL ----------- 114 114 114
Overlap --------------------------- 54.5 4 -74
Bore 3.9
ST = Stroke 3.622
RL = Rod Length 6.098
Number of cylinders 8
Deck Height (how much pistons come out of the hole) -0.006
Piston Dome or Dish (- for a dome + for a dish) 0
Compressed Head gasket thickness 0.052
Cylinder Head Chamber Volume 64
Static Compression Ratio 10.71 :1
Dynamic Compresion Ratio 8.44 :1
Rod to Stroke Ratio 1.68 :1
Bore to Stroke Ratio 1.08 :1
Bore 3.9
ST = Stroke 3.622
