Cam or Torque Conv. what if i go cam 1st
I have a 2002 Camaro SS
I have Long-tube headers/pulley/timing/all cold air intake/suspension and was going to go with a cam before a torque converter. I dont go to the track very often and didnt know if I went with the cam first if it would be ok can you advise me on pro's and con's
Cam is 224/220 581 lift 113
Thanks
Thanks
the TC alone will gain u more in the 1/4 than the cam alone, but if ur going for a "sound" then the cam is what u want... y such an odd 'numbered' cam? is ur car an a4 or m6? if m6, just get a hotcam if sound is what u want, very cost effective... if ur car is an a4, u'll need programming...
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Yea, I would go with the converter, the car will be faster w/the converter alone...
When you add the cam w/the converter, then it will be a big gain...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
With that cam, your car will be a dog in the low-to-mid range area(it'll take your stock converter forever to reach the higher powerband).
Definitely go with the stall first and then the cam later on to compliment it accordingly.![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Mike
Mike
Mike
Mike
I could not agree more, without question do the converter first.
