where did u put bung for oil temp sensor?
I think the best place is truly the low oil sender spot w/ the resistor...
?? ooooo k.. and??? whats your point?? there are hundreds of people using it that location..
what i was telling people is that i have done the before and after.. before headers i was getting accurate readings of 200-210*.. now that i have header primary tubes sitting 1" away from it..heating up the aluminum plug, where my sending unit resides. temps are now @ 240+ under the same driving conditions, and oil viscosity..
SO... it appears to be heatsoak from the primary header tube causing inaccurate temp readings.
