Factory Rev Limit
Old Jul 16, 2007 | 01:07 PM
jimmymac's Avatar
Default Factory Rev Limit
Have a early 1998 LS1 camaro engine in my replica cobra 427. The ECU was modified to remove the emmission controls which we do not require in the uk. The rev limiter is cutting in about 6600 which seems high for a stock engine can anyone tell me what the factory limit should be as i dont want to hurt the motor.
Old Jul 16, 2007 | 01:15 PM
CavPat's Avatar
I think it's set at 6200 factory.
Old Jul 16, 2007 | 03:55 PM
RZRSEDGE's Avatar
I think so also.
Old Jul 16, 2007 | 06:08 PM
nobreaks254's Avatar
6200. Could the tach do off that much?
Old Jul 16, 2007 | 06:50 PM
NC98Z's Avatar
Hell no them 98 tachs are slow. You better put it back to stock. Cause if you spin a 98 too high your rod bearing is gonna fry. And I speak from personal experince. Short blocks are expensive. Now a question for you. How much does a replica car like your weigh with an LS1 in it? I'm real curious cause I've always wanted one.
Old Jul 16, 2007 | 06:55 PM
ThirdGenLS1's Avatar
yes rev limiter is set for 6200 but the shift point on an auto is 6k from 1st to 2nd then 5900 after that
Old Jul 16, 2007 | 07:40 PM
bad6as's Avatar
wired i have my harlem shift light set to come on at 6200, havent hit the rev limiter with it yet.................
Old Jul 17, 2007 | 11:56 AM
jimmymac's Avatar
Thanks Guys.
Its an aftermarket Rev counter so i am hopeing its over reading. Will keep the revs down to 6000 till i can it checked. The kit is a Gardener Douglas 427 it wieghs 1050 kg with driver and fuel think thats about 2210lbs. Its done the 1/4mile in 12.9 stock engine and poor traction 2.02 for 60 foot!
Thanks again for the information. cheers
Old Jul 17, 2007 | 04:14 PM
Happy Jim's Avatar
Jimmymac,
Snap on the GD with an LS are you running the LS ECU or one of Andy's Omex units?
I only ask as I had to tweak the output of the LS ECU to drive the Smiths rev counter properly.
But more to the point....if you are running a '98 LS ECU and coming to Bruntingthorpe on the 8th then I could do the tweaks for you (I've got EFI Live and '98s are on a free licence )
Cheers
Jim
Old Jul 17, 2007 | 06:02 PM
jimmymac's Avatar
Hi Happy Jim
Yes using the output from the LS ecu didnt fancy Andys Ecu. What"s happening on the 8th? Which tuner do u use as i am going have to get a HP or EFI but unsure.I am glad i have not been over reving as its a sweet engine.
cheers James
GD 427 LS1 T56
Old Jul 18, 2007 | 12:43 PM
Happy Jim's Avatar
Hi James,
Drop a mail to Andy, looks like you've just dropped off the mailing list - They've got their "Open Day" on Sat Sept 8th at Bruntingthorpe - which means many hours of howling round the track .
I've gone for EFI Live (deceision based on gut feel after visiting both camps and listening to the (naturally) very biased feedback of each!. You can download EFI Live and play with it before you buy the hardware if you fancy.
Regards
Jim
