TSP H/C package
Old Jul 17, 2007 | 08:02 PM
CodeName Z06's Avatar
Originally Posted by lildut
I made 443.00/420.99 and with a 75 shot I made 519.21/532.97. I plan to spray 150. I havent driven it yet because my qtp electric opener was stuck closed, so right after it got tuned, my car was brought straight back to the shop. these numbers are actually lower than what it should because the qtp electric opener was stuck closed. That cause my exhaust to reroute through the muffler. That really restricted my exhaust flow because I have Borlas and its designed to flow straight out, so there was restriction on the chart. How much, I dont know. It could be from 5hp to 15 and up hp.
How streetable is the Toruqer 3 vs the Torquer 2? Is you car a daily driver?
Nice numbers thats what type of numbers i am looking to get
Old Jul 17, 2007 | 08:11 PM
lildut's Avatar
THANKS MAN.
I don't know about the toruqer v2. I was going to buy the V2 but I say the T3 and went with that one. Yes my toruqer v3 is streetable. Before the tune, It was very aggressive but now it idles well, really well. Yes my car is a daily driver. good luck on your numbers.
Old Jul 17, 2007 | 08:14 PM
MVDCGTO's Avatar
The V3 is a revision of the V2 with LSK intake lobes, hence the much higher lift. The cam should lope pretty good but I'm hoping drivability will be good. Thats pretty much the reason I chose it over larger duration cams, and the better under the curve power production.
Old Jul 17, 2007 | 08:22 PM
Did you get the 111 or 112lsa?
Old Jul 17, 2007 | 08:28 PM
MVDCGTO's Avatar
111 lsa.
Old Jul 17, 2007 | 08:42 PM
lildut's Avatar
same here... 111
Old Jul 17, 2007 | 09:34 PM
jegten's Avatar
Originally Posted by MVDCGTO
Will do. My installer/ tuner is booked up for the next month so I will get back after then. Oh well, good things come to those that wait huh.
glad you found the info!!
let us know.
Old Jul 17, 2007 | 10:45 PM
SweeTbone's Avatar
Hot ****! Fellas with the Torquer V3, what are you full list of mods? I'm in the middle of my cam swap, and was estimating around 410 RWHP for mine. 443HP/421Trq is pretty damn good. Any chance of shooting me that graph as well? Thanks.
Old Jul 17, 2007 | 10:46 PM
neverenuff's Avatar
02 TA M6 PRC stage 1,torquer 3 111 lsa,long tubes,ory,slp catback,lid made 420/393 with a nice flat curve and is streetable.fast 90/90,pulley,and 100 shot still to come.
Old Jul 17, 2007 | 10:53 PM
MVDCGTO's Avatar
Well I have a '04 LS1 GTO M6 and once everything is installed I will have PRC stage 2.5 heads, torquer v3, ARH 1 7/8" LTs, Spintech catback, CAI, and a ported oil pump and as I have said if I hit 420rwhp I will be extremely happy. It seems like the torque curve from this cam is really nice and gives nice torque down low, which is where my car needs it as it weighs 3700lbs without me in it. I will post back in a little over a month once everything is done.
Old Jul 17, 2007 | 11:03 PM
neverenuff's Avatar
shouldnt be a problem
Old Jul 17, 2007 | 11:41 PM
  #32
lildut's Avatar
anyone that want to see my graph, send me your email so i can send the attachment. I dont know how to put it on ls1 tech. It says that the image is too big
Old Jul 18, 2007 | 12:43 AM
  #33
chae's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/731216-texas-speed-prc-5-3l-stage-2-5-heads-what-cam.html
