pushrod size for TR 224 cam..
hmmm... was just rethinking... I think my above calcs are flawed... if the base circle is .030 smaller, then you would only need a .015" longer pushrod right? In which case 7.415 - .040 = 7.375 in which case I believe the stockers would still be ok...
You can easily measure this base circle distance with a micrometer. Measure across the cam's lobe (the lobe's smallest distance across). You will find that it is 1.552” on a stock LS1 cam. You will need to cut this distance in half in order to get the cams "centerline to lobe heal" distance. The stock LS1 cam has a .776" centerline to lobe heal distance (19.7mm).
This centerline to lobe heal distance is what is important to you in determining lifter preload.
A TR-220 cam has a 1.502” across the lobe base circle. Cutting this number also in half will equal a 0.751” centerline to heel distance. This is a 025" smaller centerline to lobe heal distance than the stock cam. (Your TR224 may be around .027" smaller)
To be very accurate, you would then need a pushrod that is .025" longer than stock to achieve the same spec lifter preload as you had with your stock cam.
These aftermarket pushrods come in .050" length increments, so in this case, a stock 7.40” pushrod would be ok.
Remember, hydraulic lifters, due to there design have a + - preload variance that the lifter can operate within. It don't need to be exact. Just get it as close as possible with the various pushrods that are available (in .050" increments)
Be advised, milling the heads will change all this and require shorter pushrods equal to how much is milled off the heads (see below).
So, to re-iterate all this:
1. If your cam has a .025" smaller centerline to lobe heal distance than stock, you would need a .025" [longer] rod.
2. If you just milled the heads .025", you would need a .025" [shorter] rod.
3. Combine the two, and your stock 7.40" pushrod would be perfect … It then becomes “tit for tat”
Ron,
IE:
TR224 cam = .027" smaller cam centerline to lobe heal distance. Needs a .027" longer rod
Heads milled .020" Needs a .020" shorter rod
Combine these numbers, and you will have .007" [less] preload than you had before with stock GM rods.
Now install Thunder 7.50" rods = .015" longer than stock. Now your lifter preload will be .008" (8 thousands) more than it was when stock.
Again, .008" is nothing. No problems at all...
See how this all works?
Ron,
Also seen a 01 LS1 with .030 shaved that needed 7.35's.These cars run a TR224.
I would rather have .020-.050 preload than .080 anyday.Less chance of floating the valves.
