Lobe Seperation Angle
Old Jul 24, 2007 | 09:17 PM
d-1sc408's Avatar
Question Lobe Seperation Angle
Ok, I realize the general idea of lsa, and what results it gives such as a choppy idle...but when you change your lsa, what are you actually changing? What benefits and disadvantages does it actually have and is it good to have a higher or lower lsa???
Old Jul 24, 2007 | 10:59 PM
chae's Avatar
Check out these articles:
http://www.engine-builder.com/ar/eb10732.htm
http://www.superchevy.com/technical/...n/0511sc_cams/
http://www.popularhotrodding.com/tec...mshaft_basics/
Old Jul 25, 2007 | 12:54 AM
Raise's Avatar
take 2 cams with identical duration and lift but 2 different lsa. just for an example, lets compare a 224/224 .563/.563 112 lsa and 224/224 .563/.563 114 lsa. the tighter the lsa, the more valve overlap(the time measured in degrees that both the intake and exhaust valve are open at the same time) you produce. this gives you that choppy idle. of course a wider lsa will produce a smoother idle, though it will suffer in the low rpm range where good torque for the street is desired. correct me if im wrong Predator or Patrick, but i believe a tighter lsa will bring on power a little sooner, but the wider lsa will give you a nice flatter/broader curve...and might hold power a little longer at the end of each gear.
Old Jul 25, 2007 | 01:00 AM
Raise's Avatar
by the way, those are some great articles Chae
Old Jul 25, 2007 | 07:21 AM
N4cer's Avatar
Here's a basic idea of how I've seen it play out in the cars in my area. This is just a general idea I drew really quickly, but you can get the point:
Old Jul 25, 2007 | 07:23 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Good graphic!
Old Jul 25, 2007 | 04:08 PM
Dragkid1917's Avatar
i thought basically the lower lsa would just shift the power curve to a higher rpm, much like the diff between the v.2 and the v.3 torquer from tsp, the v.2 even with a longer intake duration has its power starting 600 rpm less then the v.3, mainly because the v.3's standard lsa is 111 and the v.2's is 114.... also,the v.3's intake lobe is higher, but that should have no effect on peak hp (in rpm band, not the actuall hp value)and rpm range.
Old Jul 25, 2007 | 04:13 PM
N4cer's Avatar
You thought wrong. And how do you know where the power starts with every setup anyway? Those ranges are just examples. They're not accurate. That's why you can't compare those numbers between two companies.
Old Jul 25, 2007 | 06:45 PM
d-1sc408's Avatar
awesome graphic that really helps me visually in understanding....also the websites were very informative...thanks for the help you guys
Old Jul 25, 2007 | 09:02 PM
yhea but you can compare within the same company.... look at tsp, compare the V.2 and the v.3 and there power curves, the v.2's specs are 232/234 .595/.598 114 Standard LSA and the power band from TSP is 1800 - 6400 rpm. The v.3 is 231/234 .643/.598 111 Standard LSA, and the power band fron TSP, the same company that rates both, is 2300-6700. and the PEAK is 6400. To me, it seems like the peak hp in the v.3 is right on top of the RPM power band range for the v.2 Even with its bigger duration its power band is lower, that to me, seems like it has to do with the LSA being 3 bigger then the v.3
Old Jul 25, 2007 | 10:44 PM
N4cer's Avatar
Peak is 6400 because of the intake, not the cam.
Old Jul 26, 2007 | 12:54 AM
TXws6's Avatar
+1 thanks for sharing those!
Old Jul 26, 2007 | 07:06 AM
brad8266's Avatar
LSA alone is meaningless sort of. Lobe seperation combined with duration is where you get most of your valve events from and is what determines your overlap period, which really will determine how much your motor chops. For a given duration on a cam if you make the LSA numerically higher the overlap period decreases.
The more overlap you have the choppier the car will idle and run at low RPM because more overlap causes there to be less vacuum in the engine, but at high rpm it aids in forcing a fast rush of air through the engine. Its like the rush of exhaust gas out sucks along fresh air in during overlap, and this rushing is great at high rpm. Thats why big cam cars breathe so well up top.
Old Jul 26, 2007 | 11:28 AM
i read the cam guide backwards....just read it again and realized that... sorry....
Old Jul 26, 2007 | 12:17 PM
Thule's Avatar
some good answers here,
