Quick reusing cometic question
Old Jul 29, 2007 | 02:05 PM
ss_girl's Avatar
Default Quick reusing cometic question
I'm planning on reusing a set of cometic head gaskets. I sprayed them with copper gasket spray the first time around. Do I need to clean that off and what should I use?
Old Jul 29, 2007 | 02:09 PM
JPH's Avatar
JPH
i would. use soap and warm water to clean them up first, respray them and go. i like to use spray hylomar in my s/c and nos engines.
Old Jul 29, 2007 | 08:35 PM
ArcticZ28's Avatar
Copper gasket spray is just fine for reuse. I would just clean the mating surfaces of the heads/block very well, respray the gaskets, and put them back on.
Old Jul 30, 2007 | 07:29 AM
radkon's Avatar
Why risk your engine over a set of gaskets? I know they "can" be reused but I wouldn't.
Old Jul 30, 2007 | 07:40 AM
1999ssls1's Avatar
Because they are made to reuse.
Old Jul 30, 2007 | 08:35 AM
N4cer's Avatar
No, they aren't "made to reuse". They're made for single use. But the design of them has shown to be "capable of reuse".
Old Jul 30, 2007 | 08:54 AM
brad8266's Avatar
Dont even bother to reuse them, just get new ones. Its not like they are that expensive so its not really worth it to risk a leak.
Old Jul 30, 2007 | 12:33 PM
slow trap's Avatar
i reused one of mine but partly because i just took one head back off to change out a lifter.i put mine on without spraying them,no leaks so far (knock on wood)
Old Jul 30, 2007 | 01:02 PM
snake charmer's Avatar
i have heard of them reused but i would just buy new ones for the peace of mind .
