largest stroker kit with stock bore?
Nowadays, 402s and 416s can be had for only a few hundred dollars more than a 395 kit + machining costs. Plus, if you buy the shortblock outright, you then have a complete LS1 shortblock to sell on ebay for a few hundred bucks. At the end, the difference will probably be less than $500. And a 402 will definitely outpower a 395 due to the larger bore, which unshrouds the valves and allows for more flow/power.
No matter what you do, you increase CI, you will increase power rest assured of that.
