Differences in years on the LS1
Old Aug 1, 2007 | 12:07 PM
Banshee Ben's Avatar
Default Differences in years on the LS1
Where can I find the changes in LS1 engines from year to year?
I'm looking at grabbing a 97 vette LS1 and would like to know if I should stay away from the earlier years, or if any changes were minor.
Old Aug 1, 2007 | 12:15 PM
WS6NIGHTMARE's Avatar
Old Aug 1, 2007 | 12:33 PM
formula001's Avatar
https://ls1tech.com/forums/showpost....80&postcount=2
Old Aug 1, 2007 | 09:44 PM
transam45's Avatar
dont get anything under a 99 block there all crap
Old Aug 1, 2007 | 10:23 PM
I wouldnt exactly say that, but why do you?
Old Aug 1, 2007 | 10:37 PM
1999ssls1's Avatar
Word of mouth. He probably really doesnt know.
Old Aug 1, 2007 | 10:45 PM
transam45's Avatar
97-98 block have very small oil breath by in the bottom end and the heads are designed with parameter bolts and those block are prone to oiling problems cussing spun bearing and such..
u can still make a lot of power with these blocks but if you get one find a good machine shop that can machine bigger oiling passages in the bottom end and replace the heads with 243 ls6 or if your going to turbo it use the 317 6.0 truck heads will drop comp to about 9.5:1
Old Aug 1, 2007 | 10:50 PM
gts500's Avatar
97-98 block have very small oil breath by in the bottom end and the heads are designed with parameter bolts and those block are prone to oiling problems cussing spun bering and such..
u can still make alot of power with these blocks but if you get one find a good machine shop that can machine biger oiling passages in the bottom end and replace the heads with 243 ls6 or if youring going to turbo it use the 317 heads will drop comp to about 9.5:1
Old Aug 1, 2007 | 11:02 PM
transam45's Avatar
here some picture srry they shity pic
Old Aug 1, 2007 | 11:09 PM
Wow, someone did some searching in a hurry.
Old Aug 1, 2007 | 11:12 PM
transam45's Avatar
lol
Old Aug 2, 2007 | 12:24 AM
I did a search and didn't find all this good info. Thanks guys
Old Aug 2, 2007 | 12:59 AM
85ta383's Avatar
lots of us run 98 blocks without issue.. but if i had my choice i would go with a 99 or above as stated.. unless it was a helava deal on the 98.
Old Aug 2, 2007 | 07:30 AM
1999ssls1's Avatar
Ok, so you did know. lol
