340 RWHP 383 Stroker ?
a call is cheap and he can prob get you into a better cam setup and where you should be sitting
mti's number- 281-870-8787
Steven
RUF:
ttt for you!
thanx ruff , we are still waiting for your dyno #"s !
I should have the car by tomorrow and should be able to dyno next week. I drove it a bit and the Yalla Terra really quite the engine down! It pulls harder at higher RPM than before. I will let you all know how it goes!
Personally I would go pretty big. 236/244 112LSA.
Cheers,
Chris
Can you list all your mods, and your exhaust setup, and your AF ratio for the last two dyno sessions?
im out of breath hope this helps ... b
12:5:1 AF
36 lb injectors
26 degrees of timing
230/237/114 or bigger camshaft
-Keep it at 114 LSA the 112 stuff runs out too quick.
I have to run, I'll type more later.
Remember, Nineball's 382 big bore ran well with just the old T1 cam (221/221). Yes, Tony got more power with the T2, but it wasn't as huge as one might expect. Also, JPR has had good results with a TR 224 (also big bore).
Hopefully you'll find some other factors, like tuning. I doubt the cam is worth more than 30 - 50 HP.
I'd change that and go like 232/237//114//+2.
3" exhaust will be worth more HP, but IMO you need to change the cam first, dial in your AF ratio and go from there. If you can't get your car's AF from a dyno, then I would go .900 on the 02's. 26 degrees of timing should be fine.
