what deffernt between 241 and 243 heads ?
Old Aug 9, 2007 | 03:41 PM
0utLawZ28's Avatar
Default what deffernt between 241 and 243 heads ?
can some one tell me the difference between the 241 and the 243 heads and wich would do better on a stock ls1 i have a cam that well be going in when i get the heads here the specs which head would be better with this cam?
Lobe lift:
0.326" i
0.568" e
Valve lift (1.7 rocker):
0.554" i
0.580'' e
Valve lift (1.8 rocker):
0.587" i
0.601" e
Advertised (total) duration at 0.006":
261° i
277° e
Duration at 0.050":
208° i
224° e
Lobe separation angle (LSA):
117
Old Aug 9, 2007 | 04:02 PM
transam45's Avatar
i think there both ls6 heads but im not sure but you going to need some springs for that cam i think ls6 springs max out at .550 u might try 918 if your going cheap they can handle .600 lift but you have to replace them after 30k miles
Old Aug 9, 2007 | 04:08 PM
BREWS02WS6's Avatar
Wow learn to type. But the 243s are LS6 heads, better flowing than the 241 LS1 heads.
Old Aug 9, 2007 | 04:13 PM
Gunnar@Patriot's Avatar
A 241 casting is a LS1 head that comes with a 67cc chamber and flow around 220 stock. A 243 catings is a LS6/LS2 head that comes with a 64cc chamber and flow around 240 stock.
Old Aug 9, 2007 | 04:38 PM
0utLawZ28's Avatar
so can i put the 243 heads and the the cam on my car with just valve springs and will the valve clear the pistons ? or do i need push rods also will i need to tune the car or can i drive it with out a tune ?
Old Aug 9, 2007 | 05:53 PM
Omega Doom's Avatar
damn, I thought they bloth flowed more then that?
Old Aug 9, 2007 | 07:58 PM
0utLawZ28's Avatar
does any one know if ill have any piston to valve problems ?
Old Aug 10, 2007 | 08:32 AM
gts500's Avatar
no man no piston to valve problem with stock 243 or 241 >
Old Aug 10, 2007 | 12:58 PM
98Camarod's Avatar
But you will want to upgrade the springs to atleast 918's
Old Aug 10, 2007 | 01:43 PM
CodeName Z06's Avatar
And some hardened pushrods
