Roller Rocker Problem
Old Aug 13, 2007 | 11:16 PM
Camaro_or_TA's Avatar
Default Roller Rocker Problem
We just installed a new set of roller rockers on a Ls1. We torqued the roller rocker arms on at 22ft/lbs. We made sure we buttoned everything back up and when we tried to start the car it barely managed to turn over twice the first time, it wouldn't start, and every time we tried to start it after that it wouldn't even turn over. I'm thinking that we tightened the roller rocker bolts on too tight. If anyone can give any feedback or a detailed guide other then the Yella Terra guide, because i used that guide and aparrently the torque specifications are wrong, because we put everything back on perfectly.
Old Aug 13, 2007 | 11:50 PM
Killer_Bluebird's Avatar
22ft/lbs is correct.
Here is a guide. The rockers are the old style rockers. Do you do any other changes other than the rockers?
Old Aug 14, 2007 | 12:24 AM
PRC Dual Spring Valve Springs, Texas Speed Hardened Pushrods, MS4 Cam, stock heads. I'm beginning to think that the battery is dead, but i hooked it up to my friends ????? and it still didn't start up, so we're going to check things out and see if we missed something, and the Yella Terra guide is the same one I used, I'm not using those type of Roller-Rockers, mine are not attatched they're independant..
Old Aug 14, 2007 | 10:13 AM
1CAMWNDR's Avatar
Make sure you recheck the rocker arm torque after turning the motor over 180°. Sounds like battery to me also.
Old Aug 14, 2007 | 01:42 PM
Mike@TEA's Avatar
Are you using a comp cams or crane stud mounted roller rocker?
Old Aug 14, 2007 | 01:59 PM
Randy WS6's Avatar
They make ajustable and nonajustable, witch do you have?
Old Aug 14, 2007 | 02:35 PM
BadgeZ28's Avatar
If they are independent and have a center adjustment nut, you don't use the 22 pound torque. With 22 pounds torque, you have completely bottomed the lifters. I am now doing some Comp cams individuals and on my motor .0060 preload is one full turn after the rocker reaches zero lash. I am adjusting the intake when the same cylinder exhaust valve starts to open and I adjust the exhaust when the intake has reached full open and just starting back up.
Old Aug 14, 2007 | 06:41 PM
Randy WS6's Avatar
I do mine just like BadgeZ28 does, with my Comp Cam Pro Mag. roller rockers. If your are adjustable and you torque them down to 22 ft-lbs. your valves are hitting your pistons and locking your motor up, try loosening your rockers back up and try to turn the motor.
