Dual valve spring question....
Old Aug 16, 2007 | 11:55 PM
ws6_bandit's Avatar
Default Dual valve spring question....
I guess im not exactly sure what the difference is between single and dual valve springs. Im assuming the dual springs are rated at a higher lift?? Do they look different than single springs??
Old Aug 17, 2007 | 07:23 AM
Viper's Avatar
A dual spring is just that, 2 springs, one coiled inside the other. They look different and are typically rated for higher lift.
shows a single on the left, dual on the right.
Old Aug 17, 2007 | 07:42 AM
Gauge's Avatar
11Second Club
Duals add another layer of security because the chances of breaking both springs is slim. However, the inner spring is usually quite weak, so you can still very easily get P-t-V contact.
Old Aug 17, 2007 | 07:58 AM
ws6_bandit's Avatar
I see. So the TR 230, being a "lower lift" cam, would be safe with single springs. btw its a .575/563.
Old Aug 17, 2007 | 02:46 PM
robertbartsch's Avatar
Some single springs are safer than others!
Old Aug 17, 2007 | 03:38 PM
GuitsBoy's Avatar
Which ones?!? Im not sure I trust any of them anymore...
Old Aug 17, 2007 | 04:05 PM
TheLS1Kid's Avatar
^Me neither.
I'm sticking with duals.
Old Aug 18, 2007 | 04:09 AM
njc.corp's Avatar
in aus i have witness to many single springs braking-
duals all the way after some of the things i have seen-
i would rather brake a dual than a single-
Old Aug 18, 2007 | 07:57 AM
gillbot's Avatar
I run my TR230 on singles. The PAC springs are good.
Old Aug 18, 2007 | 08:16 PM
Bill Bowling's Avatar
I like the duals but they do add more mass to the valve train.
Bill
