How many of you are still running the 10 bolt with H/C?
Well I can speak for my buddy with a M6, he has been running his 10bolt for a think 2 years now with the MS3/prc 2.5's and still running strong. He has made a few trips to the track too. Before the engine was forged for nitrous 2 years ago with the H/C he ran 15 or more bottles of nitrous through it too. Hot lapping it, run after run. He isn't spraying with his current setup though until he gets a 9", he knows thats asking for it. Lucky, yes I think so. The next guy will pop the damb stocker with bolt on's, what the hell, LOL
No problemes here. 130k miles on stock 10 bolt w/ 2.73's. I think I read one time that the 2.73's are stronger than 3.23 or 3.73. Maybe because of a thicker ring gear? No track use but some racing from a role and rarley from a stop. I am on street tires so I think they are a weaker link. I only have basic rearend knowledge so take it for what it's worth.
vinci crane 66 cam full boltons tune 4k loose stall e/t streets
1.7 sixty foot leaving on a 75 shot.....goin back next month to make a 150 pass with some better weather and tuning....
oh its the stock 10 bolt with motive 373s/auburn posi/moser axles/and a richmond master bearing kit.....
the key to not busting a rear is preload....its possible in an m6 car to preload as well just takes practice....ive seen a turbo ta go high 10s on the bonestock 10 bolt......
Originally Posted by PREDATOR-Z
Still using mine (modified with Moser axels,Micronite gears and TA cover with studs).
Launching with nitrous, H/C, Vig 3800 and 370 cid
Mid low 10s to kissing 9s on juice
A4's are much kinder to the 10 bolt with preload, than a M6, especially in driveline shock on a drag strip...
I'm still running a 10 bolt. 60' times 1.52-1.54 average. Eaton Posi, stock axles, welded axle tubes, T/A girdle. I stripped an axle in May, other than that I haven't had any problems.
