Heya Tony, any pics of Jesel clearancing?
Just checking to see if you had some pics of the clearancing needed on your valvecovers for the Jesels you have.
Thanks! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
My experience is that it's more radical than just "clearancing". All the internal baffling had to be removed, which resulted in a LOT of oil being drawn into the PCV system. I've done the mod using an air compressor filter, but I can fill the reservoir in 2-300 miles of even moderate driving. Plan B is an LS6 PCV setup and aftermarket valve covers without PCV fittings.
External pcv baffling is completely acceptable, most race style engines require it.Fill cap can be converted to oil/baffle seperator also. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jsears8:
<strong> Why don't you use valve cover spacers?
Justin </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Where can I get some. Thanks alot. Are there any bad sides to using spacers?
I'll snap some photos next weekend when I visit the shop. Basically, all of that sheetmetal must be removed, as well as those plastic parts on the inside. Then everything is grinded down smooth. I believe a few of those "bumps" from the coil pack mounting bolt areas also had to be smoothed a bit. Takes a good hour per cover to prep them.
-Tony
-Tony
you can get the vc spacers from www.moreperformanceinc.com I got lucky and got a set here in the classifieds for $110 shipped! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
