Cam install problem
Old Aug 23, 2007 | 01:21 PM
F-Killer's Avatar
Default Cam install problem
Installed my new cam yesterday but had a little problem, I used two wood sticks to hold the lifters and one got stuck. Its wood from home depot so its not a hard wood. Do you think I could have any problem if I start my car like that? I was thinking on driving it and changing oil every three months since lifters go down and up without problem, but would like your opinion, thanks.
Old Aug 23, 2007 | 02:57 PM
socmguy's Avatar
Restricted User
damn, I don't know what to say. Changing oil often may work but if there is a big piece it may plug the pickup. Try spinning it over a few time and then, pull the pan.
Old Aug 23, 2007 | 05:43 PM
F-Killer's Avatar
I think I'll change oil every month and clean the oil pump filter and pick up tube since the lifters dont get stuck with the dowel, the car works fine. I guess I'll remove the engine in a few months from now and then get that thing out, thanks
Old Aug 23, 2007 | 06:12 PM
NC98Z's Avatar
I though I had heard them all. Get the stick out dude!
2001z's Avatar
if it was stuck in there it is in a million little pieces now lol. I think you should drop your oil pan and see what kind of mess you have . How big was the piece of 5/16 dowel that broke off?
Old Aug 23, 2007 | 07:59 PM
F-Killer's Avatar
It was 5/16 and I could get it out at all, really dont know the lenght but it was long as the engine is
Old Aug 23, 2007 | 09:41 PM
TheLS1Kid's Avatar
Damn dude I definitely wouldn't run the car.
If it clogs up the oil flow then you will have much bigger problems. **** wont be getting lubricated which means it will be more prone to breaking.
If you are planning on taking it out in a few months, why not just do it now?
Old Aug 23, 2007 | 10:16 PM
5_02ls1's Avatar
you cut the dowel to short didnt ya......i used the dowels but left about a foot to stick out of the block...can you get lpiars on the dowle....dont leave that in there it will destroy somthing.....
Old Aug 23, 2007 | 10:21 PM
WOTFMAN's Avatar
The best part is this cat is serious about changing his oil every so often thinking it will magically dissolve. Am I drunk reading this?
Old Aug 23, 2007 | 10:33 PM
5_02ls1's Avatar
i must be drunk as well and havnt opened the first bottle yet....
Old Aug 23, 2007 | 10:40 PM
roadtalontsi's Avatar
why did you even need anything to hold the lifters up, when i installed a cam on my friends 01' tahoe. the cam went in like butter and the lifters sat out of the way just fine. This was after removing the rockers and pushrods and turning the cam while removing.
Old Aug 23, 2007 | 10:52 PM
F-Killer's Avatar
My rockers kept falling, think I'm getting my engine out this weekend
Old Aug 23, 2007 | 10:58 PM
5_02ls1's Avatar
good idea.....
Old Aug 23, 2007 | 10:59 PM
5_02ls1's Avatar
Default 1 lifter
luck isd all i can say....imagine if 1 lifter wouldve fell....you should play the lottery
Old Aug 23, 2007 | 11:07 PM
SSdreamz's Avatar
hell no dont start the car!!!!! if you already did....time for you to start the engine R&R early
Old Aug 24, 2007 | 12:17 AM
F-Killer's Avatar
Thanks to everyone, I know I fucked it up so I'll clean my mess, hope tomorrow I can fix it. I'll let you know my results
Old Aug 24, 2007 | 06:40 AM
radkon's Avatar
So you left the wooden dowel in the engine and bolted it back up? Wow!
Old Aug 24, 2007 | 10:55 AM
F-Killer's Avatar
Yes, I had the car in a 3 floor underground parking lot and there's no way I could take it out more than driving it. I took it to the mechanic yesterday and he's checking how to remove that thing. Anyone got any idea? Can I push it from the rear part of the engine? Can I have access to it if I take the oil pan down? Pulling the head out? I was thinking on getting a long tread in it and pulling it
Old Aug 24, 2007 | 11:11 AM
bczee's Avatar
Have you removed the Valley pan on the top of the engine ?.. maybe you can use a Ice pick or something to push it back out if is still alined with the hole ? or have about using a long wood / self threading screw and screw it into the end of the dowel. (funny, using a screw to get un-screwed !LOL).
If not.. you'll most likely have to do more of a tear down then you want.
Old Aug 24, 2007 | 12:28 PM
F-Killer's Avatar
Havent removed it and dont know I'f I'll have access to it. Do you know if I remove the valley cover I'll be able to get access to the dowel?
