Catch can needed?
Old May 27, 2003 | 08:08 AM
robertbartsch's Avatar
Default Catch can needed?
I just pulled my heads and noticed lots of built up of carbon deposits on the pistons and chambers; there are also oil deposits on the intake ports....although the car ran great, I suspect these are due to recently added LT headers (intake ports were prestine before LT's went on)....
Sine I would like to avoid this in the future; is a PVC oil catch can the solution?
How do you rig these? Someone said they sell the parts needed at Sears? Which parts do I need; is there a web page on this mod?
I assume I will throw a code if I block the PVC valve, right?
Old May 27, 2003 | 10:24 AM
Z-Rated's Avatar
Default Re: Catch can needed?
What about a LS6 lower valley. Its better than a catch can..... Fix the problem with the LS6 lower valley, dont patch it up with the catch can.
Look at jmXs page on this. Here
Old May 27, 2003 | 10:59 AM
Constrictor 98TA's Avatar
I disagree. In my opinion, the oil catch can is a more effective fix for keeping oil out of your intake. It has been proven by many members that although the LS6 valley mod does help eliminate oil consumption, it does not completely stop it. The only way to effectively stop it is the oil catch can.
Old May 27, 2003 | 11:24 AM
Honez's Avatar
Here is my catch can, it was about $25 bucks at Home Depot.
Old May 27, 2003 | 12:04 PM
Z-Rated's Avatar
Constrictor, the LS6 valley worked for the few that I know that did it. But they also had low oil consumption.
Honez, can you give me some details for that?? it looks good. what did you use as a filter element?
Old May 27, 2003 | 12:27 PM
Hey Honez:
Your setup is nice; evrything is SO clean! Can you please tell me how it was made?
You said the parts came from Home Depo; what is the tin can made from; how did you incorporate the hose fittings into the can?
Thanks...
Old May 27, 2003 | 01:12 PM
ngozer's Avatar
honez, would you mind pming or emailing the info on the catch can to me also. i agree with robertbartsch, your set up is very nice.
Old May 27, 2003 | 01:56 PM
m1key99WS6's Avatar
If you look at it really closly it looks like a PVC tube 3-4 inches round, and with an end cap in each end spray painted black. Pretty neat actually. Good idea.
Old May 27, 2003 | 04:05 PM
Zeta's Avatar
No. It is black pvc.
Generally searching rather than asking about something many of people has done over the last year+ turns up more results than asking.
I researched it, built it, modded it so I never have to move it. Quite happy with it, and it looks a lot like the one above.
Old May 28, 2003 | 02:53 PM
I made mine out of PVC tubing also, but I sprayed my aluminum color. I want to revise my inlet, so I'll post pix once I have that done, however, I highly recommend this mod to anyone with an LS1 since its so easy to make and it really does stop oil consumption.
In my opinion, a filter element is not necessary. It doesn't hurt, but if you design the canister correctly and separate the inlet and outlets far enough, no oil should get into the intake.
Old May 29, 2003 | 07:10 AM
Great:
When you make it from PVC pipe, how do the tube fitings get attached to the canister?
Old May 29, 2003 | 07:16 AM
StevieZ's Avatar
I did both the valley cover and the catch can. I have a new motor with extremely low oil consumption and there is still oil that gets into the intake albiet a heck of a lot less.
Old May 29, 2003 | 09:25 AM
Great:
I drilled the holes in the top and side of the PVC tubing barely smaller than the diameter of the threaded portion of the fittings, and "screwed" them into those holes so it would thread by itself. Then once it was on, on the inside, I used PVC cement and coated around the threads to seal it up. Let it dry for a while and then installed it. No leaks.
Old May 29, 2003 | 09:54 AM
gMAG's Avatar
That is a really nifty idea guys! Great work!!
Old May 29, 2003 | 11:00 PM
BLUEBYU's Avatar
Help me here....wouldn't you want the "catch can" located after the pvc valve??? That seems to be where the excess oil would be...uh..caught. Btw, how do you empty it?
Old May 29, 2003 | 11:18 PM
Z-Rated's Avatar
Those use PVC, so just put a screw fitting on there and dump it out
Old May 30, 2003 | 09:55 AM
Zeta's Avatar
It matters not where the *PCV* is located in relation to the device. It does not stop the progression of oil into the intake.
I would be happy to let you take a look at my Lowe's special. I have collected about a cup of oil in less than 1000 miles.
