Trickflow Heads & Small to Medium Cams
Look for an older Tony Mamo thread on his original 224/228 114+1 XE-R cam in a 205 AFR headed setup.
Can you say 475rwhp ???
Big cams in a 346 that is not a pure race setup is just ego stroke. The trick is to maximize the overall combo and not just band aid it with a big cam.
Some poeple will say, it pulls like a train above 3500, my 224/222 does that too, all the way to 7000.
The majic word is COMBO and there are small cam combos and big cam combos. most big cam combos around are mismatched.
Neither the head, nor intake, nor air induction/MAF setup is maximized for those cams.
You're stating, without facts, that most big cam combos are not "maximized" while implying that most small cam combos are
If you were to put a small cam combo against mine I'm certain that said set-up would make far less power than mine
If you think the contrary . . . then you need to do more research.Regardless, dyno numbers can be "massaged" by anyone.
If you were to maximize said tiny cam set-up and run mine on the street, it would get walked; plain and simple. Over the past 6 years I've had the pleasure of racing MANY H/C F-bodies, Corvettes, and custom cars of varying degrees in varying conditions. Real-world power always shows on the street.
The "475" 224 H/C combo you refer to required the right Head and accompanying bolt-ons. Do you HONESTLY believe that a Vindicator or other large cam with the same proper Heads and bolt-ons would only produce 475???
How about this: do you believe that small set-up would pull that large set-up on the highway where the driver and traction are all but eliminated from the equation; leaving just the power of the set-ups to determine the outcome?
In the end, everyone will spend their money as they choose. This site provides information to better educate people in making said decisions. Dynos can "lie." A loss on the street or at the strip cannot. FWIW.
With a TR224 and AFR heads I made 425rwhp/403rwtq. I need a Mamo ported FAST 90/90 set up and EWP. Could hit 450rwhp.
Same Mustang Dyno.
