Help! No Oil Pressure On New motor
LS1 Tech Veteran
OK, sorry for the interruption. First I'll show you the illustration of the oil circuit in a Gen III small block.
Now, here's an exploded illustration of the oil pump.
Study both pictures and read the information to understand what happens as the oil goes through the pickup and tube to the pump then through the galley (also called gallery by GM) toward the back through the oil filter then up to the cam bearings and on upward through the lifters, pushrods and rocker arms and down to the main bearings and it all drains back to the oil pan to start over again.
The first thing that I would do is brace the engine so that you can crank it out of the car. Then I'd:
1. remove the plug with an allen wrench on the front left of the block to see if oil is coming out of the pump when you crank the engine
2. if oil comes out the front plug, replace it and remove the back plug to see if oil is making it through the filter when you crank the engine
3. If oil comes out the rear plug, remove the oil pressure sender and see if oil comes out of it when you crank the engine
I think that you get my approach to troubleshooting this problem. If you don't get oil out with step 1, investigate the oil pickup tube, O ring, etc.
Try this much and report back.
All my best with this. I know that this is discouraging at the moment, but you'll get past this point.
Steve
Steve
If it helps at all. On my dad's 72 nova, had a same issue with no oil getting up top. His new lifters that were for his 350sbc were ls1 style lifters instead of the older lt1 style lifters. They look nearly identical. He was getting basically no oil up top.....I don't know what you did/didn't replace though.
sorry to hijack the thread but how long should I have to crank the motor to get oil pressure? I just did a cam swap and replaced the oil pump. I tried cranking it for about 20 seconds and didnt get anything.
How long can I/ should I crank it to get pressure?
cranking with the coils unplugged might get you 5 lbs, if any pressure. the crank isn't turning fast enough to get it all the way to the oil pressure sending unit strong enough to register.
oh, so i should plug the fuel pump relay back in then and try it that way?
#32
LS1 Tech Veteran
68chevypu,
Yes, I would go ahead and plug in the fuel pump relay. Let the engine run about 8 or 10 seconds to respond before you get too concerned about oil pressure. Once you get oil pressure, it will be very noisy for about four minutes while the lifters pump up and then it will take the oil coming up to operating temperature and about 20 minutes of driving at moderate RPM's (no more than 3,500) for the lifters to get fully charged.
Steve
Steve
#35
I hate to hijack your thread 1999ssls1 but I am having the same exact problem with my 6.0 and can't figure it out. Here is my thread over at performance trucks are these the same problems you are having???????
http://www.performancetrucks.net/for...6&page=1&pp=30
#37
LS1 Tech Veteran
Just to give you folks a little bit of an update, 1999ssls1 and I talked for a while on the phone Sunday. He was going to try to verify his oil pressure while cranking with a mechanical gage. We discussed the orientation of the cam bearings and the fact that the hole to the journal had to be on the left side of the block and that the O ring on the dumbbell had to be toward the back of the block. Maybe he will chime back in in the next few days.
O1wtahoe, I hope that you get your problems solved too. If you want to shoot me a PM with your phone number to talk anything over a bit, please do so. I'll be glad to try to help, but no guarantees.
The internet is an interesting place in many ways. For instance, I was surprised to see my diagram from this post https://ls1tech.com/forums/showpost....0&postcount=22 appear within a couple of days over at my other hangout, performancetrucks.net. It just goes to show you that news travels fast!
All my best,
Steve
All my best,
Steve
#39
I have an engine with almost the same problem except i can get 10-20psi @ idle and no matter how many orings i have changed (6x) and 3 pumps the pressure never changes.
keep us posted on what you find out.
#40
Originally Posted by shoemike
it will take a few seconds for oil to pump up to the top of the pushrods.
unless your pushrods are too short.
