Pic of what i found on my oil drain Plug :(
#61
Originally Posted by brad8266
If the valves are ok, and the engine rotates ok I would put it right back together and run it, if it breaks later on then oh well then its time to get a new motor, until then run the one he has and start saving up. The metal shavings were a bit excessive but the motor will still run fine im sure as long as the valves are still straight.
Youre making it out to be a lot worse than it probably is IMO.
but good luck to him either way.
#63
But the smoke could just be from the timing getting messed up and opening the intake valve with exhaust trying to go out. The pistons don't look bad at all. If the heads are not damaged then I would throw it back together and see if it runs. I highly doubt there is bottom end damage
#64
How do you guys not expect bottom end damage from that?? You can see in the pics where the valve was touching the piston in both cylinders. If im wrong correct be, but doesnt that mean rod stretch or bearing failure?? I know that their isnt a significant amount of damage now but him trying to put it back together would lead him back to square one pretty soon dont ya think?? If it were me i'd take it apart just to be safe and check everything. That is all...
#65
If you're hell bent on putting it back together, please post startup vid!!! I'd recommend running it for a few minutes if it does run ok then doing an oil change to get as much of those nasty shavings out you can. I have a feeling you're gonna have low oil pressure though...did you ever check your oil level...?
My worry is that if this guy had issues like this doing a cam swap, there's much to be desired of him getting everything right when it comes to changing heads. Cleaning is crutial, so take your time and do it right, and TORQUE THE HEADS CORRECTLY TO SPEC. Muscleing the heads down improperly is gonna lead to a blown head gasket or worse...
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#67
Originally Posted by LightEmUpLs1
why does the dowel pin still need to be in there if u have 3 bolts holding them on
#69
Pour rubbing alcohol into the ports of the heads while they are off. If it leaks past the seat on the valves, take the heads to the machine shop to get them checked out and a new valve job (and probably guides) done on them. You may also consider flycutting the pistons while you are this far into the motor. I would really like to know where the extra shavings came from.
#73
Originally Posted by Beaflag VonRathburg
My main concern would be the fact that 5 and 7 are even with each other. That's pretty odd?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#76
this is what worries me... this is cylinder number 5 and 7 they are equal as far as height....![](http://i21.photobucket.com/albums/b279/Lightemupls1/IMG_1897.jpg)
and here is the lifters they are fine...
![](http://i21.photobucket.com/albums/b279/Lightemupls1/IMG_1901.jpg)
#78
Originally Posted by 2000Hawk
The LS1 firing order is: 1-8-7-2-6-5-4-3
Theres no reason that number 5 and 7 should be side-by-side.
-Joel
-Joel
