So now Im gonna buy my lifters
Old 09-10-2007, 11:03 PM
N2DP2QT's Avatar
yes definitely get the LS7 lifters, and check around there are always people selling injectors. get anything above a 30 up to a 42. you can always detune a lil and they will work fine.
Old 09-10-2007, 11:25 PM
massls1guy's Avatar
who has the cheapest SVO 30#, LS7 lifters and some upgreaded rockers?
As I understand it there are 2 GM lifter choices for the LSx's. The standard lifter is used on LS2/stock LS7. The Cadillac lifter is for LS7 racing (revs over 7k, something like that). I just ordered the LS2/stock LS7 lifter from Scoggin Dickey (sdparts.com, sponsor) for about $100.
Old 09-11-2007, 12:33 AM
Asmodeus's Avatar
Originally Posted by fortmyerspolice
Are the LS7 lifters worth it?
they are now the standard replacement lifters.. they don't make ls1 lifters anymore, they are all upgraded.
Old 09-11-2007, 03:35 PM
LSGunZ28's Avatar
why did I see a thread recently saying something bad about the LS7 lifters?
Old 09-11-2007, 04:35 PM
Asmodeus's Avatar
I dunno, why?
Old 09-12-2007, 01:46 AM
LSGunZ28's Avatar
I just read a thread about a collapsed lifter. care to explain this?
I dont wanna run into any issues with lifters. this is why im careful for what to buy.
Old 09-12-2007, 02:44 PM
Asmodeus's Avatar
ummm... it's a machined part that can fail? do you know of any lifter companies that never had one fail before? do you know what valve springs he was running? do you know if they were pre-soaked bewfore installation? do you know anything other than a lifter collapsed? I can post that a chrome moly pushrod broke but neglect to leave out that the valvetrain geometry was wrong because I used different rockers.
maybe if you had some more details instead of freaking out over someone's experience? this is why I reasearch for what I install.
Old 09-12-2007, 03:24 PM
fortmyerspolice's Avatar
What do you think he's doing? Your the one with your panties in a bunch. Quit bein an *** and respond right instead of responding with an attitude. LSGunZ28, I'm sure there was a reason that lifter collapsed. Just look into it some more before making your decision.
Old 09-12-2007, 05:18 PM
BIG_MIKE2005's Avatar
Been running mine for a minimum of 300 miles a week every since installing them with my H/C swap. I have put about 5k on it so far & done some pretty aggressive driving. I haven't had a single issue. Just pre-soak them & you should be fine. If you read something about a collapsed LS7 lifter, it's the first I have heard of it since everyone started switching over about a year ago. Was probably due to improper install or component matching.
LS7 lifters are just fine for your application unless you wanna spend the extra & step up to the caddy lifters.
Old 09-14-2007, 02:12 AM
LSGunZ28's Avatar
Thanks and thanks...
I wouldnt mind spending extra for the caddy lifters.
also what exactly is presoaking,.
ive assembled a straight-6 14 liter diesel engine and a 350 gen 1 SBC before and havent heard this about soaking lifters before.
Old 09-14-2007, 02:15 AM
Asmodeus's Avatar
You want to soak hydraulic lifters in the oil you will be using in your engine for 24hrs or so before you install them into the engine. This lubricates the internals of the lifters and makes for less time to "pump up" when the key is turned. Pretty much a standard practice and something you really want to do You don't want to fire a dry lifter.
Old 10-03-2007, 03:18 PM
  #32
LSGunZ28's Avatar
I went with caddy lifters, a bit overkill yes. But I think I will like them.. because they seem to be doing excellent for high rpms.
also I didnt go with new rockers or injectors. I talked with TSP and they said its not really necessary with my setup.
Old 10-04-2007, 03:26 PM
  #33
LSGunZ28's Avatar
LAstly... when my lifters come... I will presoak them for 24 hours in oil..
I just wanted to know, for a head cam swap would there be any break in period? I know break in is usually meant for the bottom end for the pistion rings to break in, etc.. but what should I do for heads. oh and ill be on the stock tune for a few days still..
Old 10-05-2007, 08:47 AM
  #34
CAMAROZ28SS's Avatar
alot of people say its bad to pre soak your lifters.
Old 10-05-2007, 09:02 AM
  #35
Those people are WRONG. All LS style lifters need to be soaked.
Old 12-12-2007, 11:59 PM
  #36
LSGunZ28's Avatar
Bumpp
Old 07-25-2009, 12:48 AM
  #37
98ssconversion's Avatar
im considering getting these lifters. I cant tell if I have a bent one or its because of my lt's and I guess it wouldnt be a terrible thing to upgrade anyways. Tell me how you like em! and how much the install ran you :/
