Who runs 7.425" pushrods?
Old Feb 11, 2023 | 11:43 AM
Just being able to adjust the rockers with the engine running was great! I actually cut up a pair of stock valve covers to act as shields and catch the oil before it landed on my headers.
I remember that being done. Oil on headers is no fun.....
Old Feb 13, 2023 | 12:05 PM
grinder11's Avatar
Gary, that old 1/4 turn you mention, I remember well. I wonder why the LS engines dont do that? The lifters are one of the few things that are interchangeable between ghe old and new. So why wouldnt the 1/4 turn work on the LS. Actually, the first LS I ever built used SBC roller lifters, Eaton anti-pump ups. Remember them? Anyway, never had a problem with them going to 7k rpm
Old Feb 13, 2023 | 02:18 PM
LS1Formulation's Avatar
It won't work because unlike the old smallblock, which basically had the rocker arm floating above the pushrod/ valve spring and was adjusted up and down the stud with a locknut, the LS has a smaller diameter bolt that is fully seated at all times. A non-adjustable valvetrain, basically.
Old Feb 13, 2023 | 02:39 PM
The rockers are not adjustable on LS engines. The old ones were a ball pivot and tight threaded nut. Now a needle bearing trunnion with fixed geometry fastening.
Old Feb 14, 2023 | 10:25 AM
grinder11's Avatar
My fault. I know they aren't adjustable. I should've worded it like; why not obtain just .010"-.020" preload from zero lash? I don't remember the thread pitch of the SBC rocker stud, been involved in these LS builds for so long. So let's assume the SBC used either 3/8-16 studs, or 3/8-24 studs. The 1/4 turn on the 16 pitch would be approx .016" from zero, not counting the rocker ratio. The 24 pitch would be approx .010". My memory is going 3/8-24, so about .010" preload. Whatta ya think?
Old Feb 16, 2023 | 01:05 PM
grinder11's Avatar
Any thoughts on this, guys??
Old Feb 16, 2023 | 02:12 PM
LS299S10's Avatar
That's about .100 short of what I like to run. I run my ls engines in the .100 to .120 preload range.
But to your point maybe. Remember the net lash GEN 5 big blocks? There was a stud kit available to make them adjustable like the old style. IIRC they were 8mm too. Wouldn't be too hard to set that up on an ls. Except for maybe keeping the rockers on the valve tips.
