228r + 112 lsa
Old Sep 5, 2007 | 12:44 AM
homerunhtr21's Avatar
Default 228r + 112 lsa
I just ordered this camshaft from texas-speed I wanted a 114 lsa but I screwed the order up ...How choppy or lopey <--- (if thats a word)....will this cam be at idel? I am an A4 , its my DD and I didnt want it sounding extremely choppy...Do you think it will sound ok ??? Does anybody have any clips???? HELP THANKS
Old Sep 5, 2007 | 01:57 AM
Tram's Avatar
You'll be fine..
I'm gonna get a 112lsa..
It'll be lopey but not soo lopey everyone looks at you like you are conjuring spirits..
Old Sep 5, 2007 | 07:39 AM
BlueGoat06's Avatar
there you go,
http://media.putfile.com/06-GTO-228R-112-LSA
it should lope a little bit harder in your car given the 346 ci's
slow trap's Avatar
with a fairly tame exhaust system like the hooker or similar you will be very satisfied with the 228 on a 112. idles fairly well and peaks pretty early in the rpm range so you don't have to go way up there in the rpm range to get peak performance.
Old Sep 5, 2007 | 11:28 AM
GT Griller's Avatar
Ull bearly hear it thru the hooker.
Old Sep 5, 2007 | 12:33 PM
PREDATOR-Z's Avatar
you goof up is actualy a better choice, only 4* positive overlap, I ran 9* and 13* on A4 with no issues, need a good tune. You'll like the powerband better.
Old Sep 18, 2007 | 12:14 AM
I hope I will be abel to hear it :-/ ...I guess we will see thursday
Old Sep 18, 2007 | 12:27 AM
madclown's Avatar
I just put the same cam in my M6, I have yet to start it but hopefully I will on WED.
Old Sep 18, 2007 | 01:25 AM
kingsey's Avatar
Could you run that cam with a stock converter on a 99 corvette a4?
I been looking at this
224/228 .581/.588 @ 114 + 1
Old Sep 18, 2007 | 01:35 AM
Websy21's Avatar
I have this grind brand new in box, my plans changed and I am going with a 408/turbo and don't need it anymore. Let me know, I'd let it go to you for allot cheaper than retail. Pm if interested
Old Sep 18, 2007 | 02:26 AM
PREDATOR-Z's Avatar
Yes you can, not ideal but will work.
Old Sep 18, 2007 | 07:11 AM
454mag's Avatar
kingsey,
I just installed a 224/228 .581/.588 114 +4 in my 98 a4 with a 3600 stall. I cant imagine it with a stock stall. Car idles very rough -- whole car shakes at idle at 950 rpm. its pretty smooth running after that but I cant get the torque converter to stay locked up on the hwy even after deleting all misfire stuff. Car was tuned by Slowhawk on this board. Basically I ruined my daily driver with this cam. Going to the track tomorrow to see what it will do.
Old Sep 18, 2007 | 07:44 AM
Alt's Avatar
Alt
[Subscribing]
I want to see how this pans out I have been eyeing up the 228 on a 112 for a bit recently.
Old Sep 18, 2007 | 09:26 AM
PREDATOR-Z's Avatar
Originally Posted by 454mag
kingsey,
-2* overlap and car idles rough???
Old Sep 18, 2007 | 10:21 AM
Doc's Avatar
Doc
kingsey,
That setup should not have a problem idling at 700 rpms. The shaking part may be due to some worn out 98 motor mounts.
Old Sep 18, 2007 | 10:31 AM
454mag's Avatar
Motor mounts a probably tired but the engine running so rough is whats causing the shaking. Idle is rough and varies from around 750-1100 rpm looking for 950. Also bucks and surges under light throttle on the hwy. Also has hot start issues. gonna see if the tuner will look at it again.
Old Sep 18, 2007 | 10:47 AM
Candyredz28's Avatar
by the way could the motor get damage by shacking so much at idle
Old Sep 18, 2007 | 11:34 AM
GT Griller's Avatar
lol thats what i was thinking.....its not the cams fault, u might have tunning issues or something is broken.
Old Sep 18, 2007 | 12:09 PM
Doc's Avatar
Doc
The 98 OS is not helping things.
Old Sep 28, 2007 | 08:02 PM
Alt's Avatar
Alt
And the outcome of this is??
